Page 1 of 3 123 LastLast
Results 1 to 20 of 60
Thread: TFPC for Beginners old comments
  1. Back To Top    #1
    In the Industry
    duraleigh's Avatar
    Join Date
    Apr 2007
    Location
    Sebring, Florida
    Posts
    30,131
    The keys to a beautiful pool are consistency, testing, and chlorine.
    Jason,
    That's a great sentence from a very good article.
    Dave S.
    42k vinyl and concrete pool, 1.5hp pump, 140gpm filter
    TFTestkits , PoolMath , Pool School
  2. Back To Top    #2
    Mod Squad JohnT's Avatar
    Join Date
    Apr 2007
    Location
    SW Indiana
    Posts
    9,121
    Glad to see you emphasize testing. I never use borax or baking soda, so if I had a SWCG, I'd never use any of the Bs, but IMO it's the knowledge that is the key to the method. Knowledge that comes from education and a decent test kit.
    TFP Moderator
    20K Gallon 20X36 Vinyl Inground
    Hayward S244T Sand Filter with 1HP Whisperflo Pump. Liquidator C-201 and Solar Heat
  3. Back To Top    #3
    Join Date
    Jan 2008
    Location
    Forney, TX
    Posts
    162
    Excellent article, that'll be a great link to give to people whenever they ask the "what should I be testing on my new pool" question Great idea on profiling users too, it's always neat to put a face and background to the online "voice"!
    Our pool adventure... click here
  4. Back To Top    #4
    Join Date
    Jul 2008
    Location
    Fort Worth, TX
    Posts
    7
    I just can't say thanks enough for being so specific and detailed - I'm a newbie and you just answered all my "where to put chemicals" and "how long to wait" questions. You saved me a lot of time and clicking. I hope everyone will just add this link in their signatures, and suggest it for newbie reading. Awesome job!
    10,600 gallons (15X30X54") above ground (installed 8-6-08)
    22" sand filter 1.5 hp 2 speed pump
    full sun, no trees
    BBB method
    God bless America!
  5. Back To Top    #5
    h2ctpdjl's Avatar
    Join Date
    Jul 2008
    Location
    Indiana
    Posts
    252
    Thanks so much!!!!!!!!!!!!!!!!!!!!! I did the "switch" and found the article to be GREAT! Have aslo forwarded to my friends contemplating making the "switch". Its easy reading and is in plain english that we can all understand.
    18,000 gal, 18x32 IGP, vinyl liner, 3 to 5.5ft depth. One inlet/skimmer (Aqua Genie), one main drain. Hayward Pro Series Sand Filter w/filtration rate of 20 GPM/FT, Two-Speed Pentair Whisperflo 1 HP pump, Natural Gas Hayward H200 pool heater, Aquabot T2 (200 Series) Robotic Pool Cleaner (my best friend), Automatic Electric Pool Cover (2nd best friend).
  6. Back To Top    #6
    Join Date
    Apr 2009
    Location
    Houston, Texas
    Posts
    12
    Why are the rec. free chlorine levels higher in the TFPC method?
    Noob
    10K gal, Colored Plaster, 2 HP Pentair Whisperflo pump, Pentair Quad DE filter, Paramount in-floor cleaning system w/2HP Pentair Whisperflo pump.
  7. Back To Top    #7
    JasonLion's Avatar
    Join Date
    May 2007
    Location
    Silver Spring, MD
    Posts
    37,879
    We have recommended FC levels that will be trouble free.
    Typical pool store FC levels assume very low CYA levels and make up for the problems people frequently experience at those levels by having you shock the pool frequently, typically once a week. That approach doesn't keep the water safe all week long and occasionally leads to major problems.
    19K gal, vinyl, 1/2 HP WhisperFlo pump, 200 sqft cartridge filter, AutoPilot Digital SWG, Dolphin Dynamic cleaning robot
    Creator of PoolMath and Pool Calculator. Other handy links: Support this site, TF Test Kits, Pool School
  8. Back To Top    #8
    riverheightsnancy's Avatar
    Join Date
    Aug 2007
    Location
    Flemington, NJ
    Posts
    33
    Re: BBB for Beginners
    One small question: Most of the recommendations for BBB state guidelines for plaster, vinyl, gunite, fiberglass, etc... However, I never see the recommendation for concrete pools. I can't be the only person in the entire Northern Hemisphere with one of these well-made, old guys. My pool is rubber based paint over concrete, no plaster. What guide should I follow?
    Also would that change if I get a LQ? I am particularly interested in the PH/ALK because we get consistent iron staining, even though the vitamin C works wonders, I can't keep the staining away for a long period of time or even the entire season.
    I also imagine that the recommendation would change if we change the pool surface? A rubber based paint to water based latex? we are considering a remodel of plaster over the concrete as well. Any links to this process or thoughts would be appreciated. We don't want to go from bad to worse if you know what I mean.
    1960s Original Sylvan Pool
    Concrete
    @ 30,000 Gallons
    Hayward DE Filter
    2 HP Hayward Pump
    BBB believer!
  9. Back To Top    #9
    JasonLion's Avatar
    Join Date
    May 2007
    Location
    Silver Spring, MD
    Posts
    37,879
    Paint is non-reactive and therefore is treated the same way as vinyl. The Liquidator does not change any of the recommendations. It is simply a different way of adding bleach.
    For the rest of your questions, you should start new topics in the appropriate areas.
  10. Back To Top    #10
    Join Date
    Aug 2007
    Location
    Flemington, NJ
    Posts
    33
    Ok...so, I should follow the guidelines for vinyl? Not sure I would agree with that especially in the area of CH. I have read in other threads the discussion about switching to the SWG chart when one goes with an LQ? Just curious. I guess it doesn't matter if you shoot for the middle. I wil say that I do have bits of exposed concrete in the pool. (chipping). Not sure if that would change anything. (not trying to argue either, . I am trying to become more of an expert on what really works for my pool, because it always seems a bit cloudy. Just a slight tad)
    Concrete
    @ 30,000 Gallons
    Hayward DE Filter
    2 HP Hayward Pump
    BBB believer!
  11. Back To Top    #11
    JasonLion's Avatar
    Join Date
    May 2007
    Location
    Silver Spring, MD
    Posts
    37,879
    There are a few examples of trying to use the SWG chart with a Liquidator not working. There hasn't been enough experience with it to say for sure, but so far it looks like it doesn't have the same lower FC level advantage that a SWG does.
    If you have exposed concrete, you should follow the plaster recommendations.
  12. Back To Top    #12
    Join Date
    Oct 2010
    Location
    Western North Carolina
    Posts
    8
    OMG I am so glad I found this info!!! thank you so much for posting, I only wish I would have found it this year when I opened my pool for the first time. I knew it should be able to be done this way. I am a first time pool owner this was my first season with my pool, we opened it and I have just been looking for advice everywhere. There were left over tablets from the previous owner of our house so we have been using the tabs this year and getting advice from anywhere we could. We have been testing with strips but I am going to buy the tf-100 for next year and start the season with the BBB method. It seems soooo much easier than what I have been doing. Like going to the pool store if I have a question getting told I need something unrelated buying it putting it in and then finding out I have to buy something else to fix there fix!
    25,000 capacity, IG vinyl, .94 HP pump, sand filter (Tagelus Deluxe TA-50D), 50GPM Design Flow Rate filter
  13. Back To Top    #13
    Mod Squad Bama Rambler's Avatar
    Join Date
    Jun 2009
    Location
    SouthWest Alabama
    Posts
    22,387
    Welcome to TFP.
    We've all been pool stored sometime. Spend the winter reading and absorbing everything you can here. Then next spring you'll be ready to have a Trouble Free Pool experience.
    Dave J. TFP Moderator
    24' x 52" Round AGP. 2hp/¼hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Pool School ----- Pool Math ----- TF-Test Kit
  14. Back To Top    #14
    Boy am I glad I found this website! As a new pool owner viable information is a plus. Thanx
  15. Back To Top    #15
    phipsi1237's Avatar
    Join Date
    Jan 2011
    Location
    North Las Vegas, NV
    Posts
    228
    BBB for Beginners
    Welcome!!
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
  16. Back To Top    #16
    Join Date
    Mar 2012
    Location
    Central Florida
    Posts
    2
    New pool owner here. I've been going to PAP and am trying to learn how to do the testing myself. I have been so indoctrinated into shocking weekly, I have to ask to make sure I'm understanding correctly... if using the BBB method, there is no need to shock the pool?
    Ripley2
    6500 gallon IG/pebble, Hayward C900, 1hp motor
  17. Back To Top    #17
    JasonLion's Avatar
    Join Date
    May 2007
    Location
    Silver Spring, MD
    Posts
    37,879
    Welcome to TFP!
    There is no need to shock the pool under normal conditions. The only times you shock the pool are when there is visible algae, CC is higher than 0.5, there is some other kind of obvious organic contamination, or when you are losing chlorine overnight.
  18. Back To Top    #18
    Guest
    just getting started, but the the specs for the 12% bleach i just bought says that the pH of the bleach is about 12 or so. Won't this affect the pH of the pool?
  19. Back To Top    #19
    Join Date
    Apr 2007
    Location
    SW Indiana
    Posts
    9,121
    Quote Originally Posted by wam525
    The short answer is no.
    The process the bleach goes through while being used in the pool renders bleach essentially pH nuetral in its effect on the water.
    TFP Moderator
  20. Back To Top    #20
    Guest
    Is BBB only for chlorine pools or also salt water?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
