Results 1 to 7 of 7
Thread: sand filter help questions
    Jun 2011
    Nj
    57
    i have a ranger series sand filter
    i read about channeling in the filter so decided to take the valve off and take a look in to see
    pulled the multi valve off and the pipe and laterals came right tot he top
    this is the first time i have ever dived into the fitler
    who knows what the previous owners did
    anyways the water is very dirty and full of floating things
    i back washed right before for a min and sight glass looked clear
    water is very murky LOTs of solids floating around
    put the hose in to let the solids float on and out
    a few minutes of this and nothing looked any better at all
    so i pulled the lower drain
    and leaned over the filter some to get some more water out faster
    so what should i do from here?
    how much sand should be in the bottom of my filter?
    should my water in the tank be this murky and full of solids?
    it is still draining so i dont know how much sand is there
    but i would imagine it wouldn't be much and wasnt even covering the laterals as they came right up witht he valve
    any help would be appreciated
    11,000 gal inground fiberglass pool
    Aquarite SWG system
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: sand filter help questions
    The sand level depends on the brand of filter, but normally it is about up to the point where the tank starts to taper at the top. You want the surface of the sand to be where the tank is at its full diameter, and as high as possible.
    Jun 2011
    Nj
    57
    well i deffinately dont have that
    i can push the laterals down so that about 5" of pipe is sticking out of the top
    so i guess this means i have no sand?
    why would this be?
    laterals look pretty clean and from what i can see not damaged
    but i cannot see the underside of them or the ends
    Aquarite SWG system
    Jun 2011
    Nj
    57
    ok some more drained out
    it looks like i have sand in the bottom o 1/4
    its right to where the tank starts its cylinder shaped straight up part after the bottom bowl part
    cant seem to get the laterals past the sand
    so i guess ihave to remove all the sand and put in new sand?
    Aquarite SWG system
    22,542
    Yes, you'll have to remove all the sand to get the lateral assembly to seat correctly in the receiver.
    Jun 2011
    Nj
    57
    just got back with sand
    the filter is empty with water
    the sand looks more like clay then sand thats in there
    gonna shop vac it out
    and fill with new sand
    thanks
    Aquarite SWG system
    Jun 2011
    Nj
    57
    vaccumed out the old sand
    put in new sand
    if you take a pepsi can and cut the top off with a can opener it fits right over the pipe
    centered it up and dumped in 225 lbs of sand which i searched and saw came up for a 25" filter
    backwashed till clean
    rinse
    and filter
    thanks for the help everyone
    found some white layers in my sand as i was vacuuming
    is this the DE ive been putting into the filter?
    Aquarite SWG system
