Thread: Created Spreadsheet: Calculator / Cost Bleach Requirements
    Hey all, second post here! I've created this spreadsheet based off of http://www.troublefreepool.com/chlor...46.html#p18157 and some bleach shopping on my own. If you would like to use it, just fill in just the yellow fields, all the green calculate for you. Hope someone else might find it useful too!
    Attached Files Attached Files
    Pool Size = 20,000 Gallons (I Think previous Owner said this. Used a Pool calculator for 16x32 8 ft. in deep end, Seems Right)
    Filter = Cartridge Filter, Seems really large. 2 Cartridge Filters and a little long pipe thingy in middle of them.
    Inground Vinyl Pool
    Pump Flow Rate = Unknown, though by Kill-A-Watt Meter it is 1400 watts / About 2 HP
    Pool Installation year = 1999
    Apr 2011
    North Carolina
    15
    Re: Created Spreadsheet: Calculator / Cost Bleach Requiremen
    Thanks!!!
    18' x 36' Vinyl In-Ground Pool
    New liner installed 5/14/11
    Hayward Sand Filter Super Pump VS
    North Carolina
    May 2013
    North East Ohio
    959
    I know this is an older thread, but this is awesome and thanks so much!
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    redhdgirl417's Avatar
    Sep 2012
    Mid-Michigan
    127
    13,900gal 24'x52" Backyard Leisure Heritage AGP
    20ml All Swirl Flat Liner
    Pentair 1.5hp Pump and 150# Sand Filter System
    Smart Step Ladder w/Smart Light
    TF100 test kit, BBB Baby!
