Thread: New Pool Build - Plumbing questions
    Builder hasn't been back to see the end result of the plumbing yet, but so far he's ignored my other plumbing concerns without actually looking directly at the issue, which was already covered in dirt.
    So I'm reaching out to everybody here to see if this is going to be an issue in the long term. The pipes were installed at angles and are currently hovering above the soil, so I'm concerned about long term stress loads after backfilling, decking, and future soil movements. I don't think the pictures do it justice, but is this a valid concern?
    ~8k gallon IG Pebble Sheen pool with spa. Hayward EcoStar variable speed pump. Hayward SwimClear cartridge filter C3030, 325sqft. Hayward Universal H-Series Low NOx heater 250k BTU. Hayward Aqua Rite SWCG.
    Apr 2012
    Klein Tejas
    249
    Re: New Pool Build - Plumbing questions
    OMG, that's why I'm doing my own plumbing.
    Pool is DONE!
    Pentair Intelliflo VS3050
    Pentair Easy Touch 8 + actuators + swg
    Pentair IntelliPH
    Pentair 400btu HD heater
    3- Jandy WaterColor LED's
    Hayward C5030 525sqft cartridge filter
    Waterway spa blower
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Ok my father was a master plumber and he would never have lines that looked like that!!!!!!!!!!!!!!!
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    That is common enough and does not normally pose any long term problems.
    I live in an area with a lot of soil movement (Houston, TX area), as can be seen in the sidewalks and foundations all over the area after the drought last summer, so my main concern after the initial backfill and deck pouring is soil movement. We had the plumbing at the water meter break last year, so it is a concern in my mind.
    I'm no plumber, but I just don't get the feeling that this is normal. The plumbers had to come back to re-route the plumbing due to their initial laziness that they didn't get away with, so my guess is they didn't put much effort into it.
    Thanks, Jason. Sorry, I didn't see your post before I responded. It makes me a little more comfortable, but I don't have a lot of trust in contractors from my previous experiences over the years, so I tend to second-guess everything.
