Hello. New to here. We have a 28 ft above ground circular pool. We have drained it several times to get the water right and finally we got it right. Alas though - we did leave it un drained for a while and didn't necessarily keep all of the bottom wet =(. Some sides did boe a little bit. (probably from heat) After we filled it back up we noticed a leak somewhere. Didn't know where though. Praying to god that its not the liner. Tried the dye trick and didn't find anything. Actually did it inside the pool and on the outside where the water is coming out hoping that if there was a liner leak - that the dye would somehow get inside the pool. either way - nothing. cant see air bubbles anywhere so our assumption is that it was leaking at the jet area/skimmer area. it seems to have quit leaking once it hit a certain point. Problem is though, water is still coming out from the bottom - yet the level doesn't change at all. My next assumption is that there has to be water in between the liner and pool wall because the sand is also now coming out. (again, no level change). Is there ANY better way to have this water drain out or is it just really a waiting game? I really don't want to do anymore damage than I already have.
