Thread: CH went from 300 to 230 in 24 hrs
    Hello,
    The CH dropped from 300 yesterday to 230 today. Is this common? If so, what effects can it have, if any?
    Yesterday's numbers:
    FC = 5
    pH = 7.4
    TA = 100
    CH = 300
    CYA = 30
    Temp = 80
    I added 580 oz of 6% bleach to bring FC to 13 (I feel like I'm in shock mode all summer).
    Today's numbers:
    FC = 9.5
    pH = 7.6
    TA = 110
    CH = 230
    CYA = 30
    Temp = 86
    Thanks for any advise.
    Sirena~
    Phoenix, AZ
    35-40K gals; Sand Filter; In Ground; Plaster; Sta-Rite System3 130 GMP.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: CH went from 300 to 230 in 24 hrs
    I suspect testing error.
    Calcium doesn't just disappear. The only way it went down was if you drained and refilled a quarter of your pool. But CYA didn't drop the same amount, so you obviously didn't drain.
    I'd actually be suspicious of both those CH results, since Phoenix is noted here on the forum as having very hard water with very high CH readings.
    Jul 2011
    Myrtle Beach, SC aka Redneck Riveria
    125
    Your pool rose 6 degrees overnight????
    What are you using to test your water? Test strips? Taylor?
    "When your pool is sick, call the doctor, I make house calls"
    One stop pool shop, I do everything but install them. 9+ years of experience.
    I thought it was a testing error also, so tested it twice. I haven't drained any and Phoenix does have hard water. We had a little rain overnight - less than 1/2 inch. CH has been around 300 for about a month now. It was much higher.
    Using the Taylor test kit. Yesterday's temp is probably an error as the thermometer is difficult to read. Since it was overcast all day yesterday, rain overnight, and temp this a.m. is 86, it would make sense that I misread it and was probably 90.
    Sirena~
    Phoenix, AZ
