Results 1 to 8 of 8
Thread: Sources for Valve,WhispFflo WFDS-24 and Hayward S310T2
    May 2008
    Glenside, PA
    19
    Looking for best sources for the following items. Since it's alot altogether hoping to save a little on each.
    VALVE:
    Need to replace my 3-way Jandy valve. I'll have (2) 1.5" lines coming from pool and 2" from valve to pump. Found a Jandy Never Lube 4715 on Ebay for $47.31 shipped: http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0235924552
    Whisperflo WFDS-24
    Best deal so far is $478 shipped: http://www.poolsupplypros.com/product_i ... cts_id=422
    Hayward S310T2 Filter
    Ebay - aqua-superstore -$485 shipped: http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 4446866937
    TIA! Ken
    KenJ
    Glenside, PA
    16x32 Vinyl IG, 21K Gals
    1 HP, 2 Speed Whisperflo (WFDS-24) pump, Hayward S310T2 (31"!) sand filter
    Jacuzzi 4-Wheel Tracker vacuum; cheap fountain water feature but great for raising pH
    My layout: http://www.geocities.com/irishkenj/pool.jpg
    May 2008
    Glenside, PA
    19
    Hey gang -
    I want to order ASAP as I'd like to have everything up & running by Memorial Day. Anybody have any experience with homesuppliesandmore or aqua-superstore on Ebay? How about poolsupplypros.com?
    Any and all recommendations appreciated!
    KenJ
    Glenside, PA
    Mar 2008
    Los Angeles, Ca
    222
    I bought one small thing from poolsupplypros.
    Had no problem with them, would use them again
    Randy
    25,000 gal fiberglass pool, Raypak 200k BTU H200FDN gas heater, Pentair CCP520 520 sq ft Cart filter, Max-Flo VS2303VSP pump. iWave wireless remote,
    seperate spa, with own pump, cartridge filter, Hayward H200FDN heater
    Dec 2007
    Central New York
    504
    I got my filter from:
    http://www.amerimerc.com/inground-sand- ... -mount.htm
    I got my valves from:
    http://www.westsidewholesale.com/index. ... 1.4777@@@@
    I had no trouble from either place. The box on the filter was ripped some; the filter was OK.
    Just MHO
    Attached Files Attached Files
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    May 2008
    Glenside, PA
    19
    Thanks for the input. I received an email back from poosupplypros and they will price match. Since they had the best price on the pump and close on the filter and, most importantly, their willingness to work with me, I will most likely be ordering everything for this project through them this afternoon. Will keep you posted.......
    -Ken
    KenJ
    Glenside, PA
    May 2008
    Glenside, PA
    19
    Just to follow up - good news and bad news.
    I ordered everything (pump, filter and Jandy valve) from poolsupplypros.com and they were quick to take my order and get it shipped. Unfortunately the black plastic ring/base for the filter was crushed in shipment and now I'm trying to get it replaced.
    This filter (Hayward S310) is flippin' huge! I spent part of the weekend breaking up the old pad that was just big enough for the old pump & filter so I can pour a new one this week!
    Now for the question - how is Hayward related to Pentair? Ths filter I ordered was a Hayward but they put me in touch with Pentair to get the replacement part.
    Anyway - hoping things gets worked out soon as it startes to warm up here in Philly.
    Thanks! Ken
    KenJ
    Glenside, PA
    Hayward and Pentair are the two largest suppliers of pool equipment. They compete with each other.
    May 2008
    Glenside, PA
    19
    Up & running
    It was close but I'm done. We had over 100 people over on Saturday for a graduation party for my son and as of Thursday mornig I still didn't have the new base for the filter. I used the broken one to get the plumbing completed and then the base showed up early afternoon. I got everything put together and my electrician friend came over Thursday night to tie in the pump. He finished adn the pump would come on and drain the basket but wasn't pulling. Kept trying and no prime....****!
    By now it was dark and decided to try again Friday morning. Well same thing happened and decided to re-check the unions in the lines and sure enough one wasn't tight. Tightened it and I was in business. Took the cover around noon and by 6:00 we were swimming. Since I found this and a prior website I am amazed how great my water is when I open in the spring.
    In the end I thin working through poolsupplypros.com was worth it and I would hiughly recommend inspecting any shipments (pool or otherwise) immediately in case you ruin into a problem.
    Thanks again! Ken
    KenJ
    Glenside, PA
