Results 1 to 10 of 10
Thread: Weird sound coming from intex sand motor
    Hello, I installed a new Intex 1,600 sand filter a month ago and today the motor started to make a loud noice. Sounds like the motor is giving up and its new. I use it 4 hours a day most of the time unless I boost the SWG. Coul it be the impeller? I shutt it off until tomorrow to see if it cools off and works again but Im worried here. If it goes, my pool will turn green before I get a replacement part from Intex. Only if I got a Hayward instead...
    Dam it!!
    19,000 gallon
    Cartridge
    IG
    1 HP Hayward pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Weird sound coming from intex sand motor
    How is the flow rate? You may have something jammed in the impeller that is causing the noise. Unplug the pump and see if anything is in the pump input port/impeller....that port is the one on the motor side of the leaf basket.
    The flow rate feels the same. As powerful as new. So I will have to disassemble the unit to get to the impeller right? From the basket through the motor?
    19,000 gallon
    Cartridge
    IG
    1 HP Hayward pump
    The noise is really coming from the back of the motor. Like when a electric motor is about to die. Is not a crumble sound. I will check tomorrow anyway. I'm new to this. Thanks for the tip.
    19,000 gallon
    Cartridge
    IG
    1 HP Hayward pump
    Just give Intex a call and they'll ship out a replacement, the same thing happened with mine last summer.
    I will do that.
    Thanks a lot.
    19,000 gallon
    Cartridge
    IG
    1 HP Hayward pump
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Can you describe the sound a little more precisely? Mind sounds like more of a rattle. It's been like it for 2 years now. It's been running 24/7 now for the last month. Seems to be fine.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Mine is diferent. It gets louder by the hour until it sound like driving a car on rims at 60Mph in a police chase. It gets like this like after 6+ hours of use. Then It starts fine the next day because its cool again. Intex is sending me a new one, and I get to keep the bad one. I will open it and check it. Would be nice to have a spare just in case.
    thanks for the help guys
    19,000 gallon
    Cartridge
    IG
    1 HP Hayward pump
    Got a replacement today. The motors at Intex were on back order so they shipped a hole unit free of cost. Great service. I ended up opening the motor to find that the front bearing was damaged. Found some corrossion on the left front motor support screw so I have to check the salt level. Maybe is to high. Anyhow I'll try to replace the bearing so I have a replacement for the future.
    19,000 gallon
    Cartridge
    IG
    1 HP Hayward pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Sounds like they too good care of you
    Thanks for reporting back on your status, it may help others with similar symptoms in the future
