Results 1 to 7 of 7
Thread: Green substance in pool after backwash
    Very new to the pool world. Have a 24 ft above ground pool and was trying to vacuum for the first time. I have a salt water system and with the vacuum still in skimmer and the filter still running, I switched to backwash. When I switched back to filter there was a green substance flowing out of the return fitting. Now my pool is a cloudy green. What is it and what do I do? Thanks
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Green substance in pool after backwash
    Welcome to tfp, Joseph71908
    Did you do a put the valve to rinse and pumped till sit glass was clear, before returning to filter?
    Green coming from the filter is likely algae, how did the pool look before you dumped the green into it?
    If it is algea, then you need to do the shocking process.
    No I didn't. It was a mistake so I just switched it right back to filter. Could there be algea ready in the hoses; I've only had the pool dor 2 weeks?
    22,553
    Welcome to TFP.
    If you didn't stop the pump when switching the valve you have probably dislodged the spider gasket. That will cause dirty water to return to the pool.
    How are you chlorinating the pool?
    Do you have a set of test results that you could post?
    My ph level is right at 7.2 and my free chlorine is at about .5 to 1.0. My salt ppm is at 3100. Is it safe to swim? I also got all the green out of pool. Salt water system is what i have. Thanks again
    It is not flowing greenish looking water anymore since last night and the pool is clear.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Post a full set of test numbers...especially cya. You should not let your FC get that low.
