Thread: New Vinyl pool problems
    Nov 2007
    Rockland County, NY
    65
    Hello All,
    Our pool project continues...a little more slowly and with more problems than I had hoped. During the winter we experienced a sudden loss of water which turned out to be the conduit for LED lighting. Pool builder says these conduits are considered " wet conduits" and sometimes this happens. He palaced epoxy in the housing and the problem seemed to be fixed. We recently had another rather quick loss of water (cause is yet to be determined)...but this time filter was running. It seems pump (Sta Rite 1 1/2 hp) ran overnight sucking nothing but air. I refilled pool and started the pump again and it seems to be working. I am worried about damage to the pump as it has a large warning "DO NOT RUN DRY" stamped on it. Should I be worried? Thanks.
    Rob
    27ft Above Ground Pool
    Sand filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Does the pool have a main drain? Sometimes even though the pump loses prime due to water falling below the skimmer, there is still some water flow via the drain, which can be enough to cool the pump. The main concern is overheating, which can damage the impeller or housing. The motor itself is air cooled, and doesn't care whether there is water or not.
    Nov 2007
    Rockland County, NY
    65
    Hey John,
    The pool does have a main drain, but there appeared to be no water at all in the trap. Is there some way to check the condition of the impeller and housing? Thanks
    Rob
    Sand filter
