Thread: Dolphin Nautilus?
    Dolphin Nautilus?
    Jus wondering if anyone has experience or knowledge of this cleaner. I have read on-line that many seem to be very happy with it. No frills unit but price seems reasonable. Any feedback would be appreciated.
    acaciolo's Avatar
    Apr 2008
    Northest PA - Lehigh Valley
    75
    Re: Dolphin Nautilus?
    This is a private labeled cleaner. It is virtually the same as the Pentair 820, which is also private labeled by Maytronics. I tested this model...it worked very well, but there were 2 things I didn't like.
    1. it doesnt' clean the tile line since it doesn't have the float handle.
    2. It was pretty unpleasant getting it out of the pool due to the lack of handle. you had to lean in and lift the 30+ lbs out of the water using 2 hands (recessed handle on each side) and you had no way to use your other hand for suport, as you do with the supreme series.
    tony c
    Monogram Custom Pools
    Owner of Monogram Custom Pools in NE PA. My Personal Pool - 1000sf gunite pebble pool with 1500 gallon spa/grotto and 500 gallon outdoor spa; Pentair i9 Intellitouch with i10x expansion panel. Screenlogic 2/iPhone
    Intelloflo SVRS main pump, 6 whisperflow pumps 2hp to 3hp, Intellichem system, ic60 salt water cell, Sta rite 400k btu heater, Pentair 120k btu heat pump
