Thread: tap water with high TA
    Jul 2012
    Riverside, CA
    51
    We will do a drain and fill to lower CYA. I tested our tap water and found TA 200ppm and CH 200ppm. I always thought we had hard water. But it seems CH is not high but TA is. Could it be the high TA that is causing the scaling problem in our pool? How to deal with it?
    20,000 gallons, IG plaster, probably built in the 80's.
    Filter: Hayward Pro-Grid DE6020, 120 GPM.
    Pump: Magnetek century E-plus, Purex Triton Whisperflow, WFE-4C, 1HP.
    Fountain booster: Century Centurion A O Smith, CAT B848, 1HP.
    Spa booster: G.E. Jacuzzi pump
    Heater: Raypak RP2100 Digital, Low Nox
    Jul 2010
    England, UK
    156
    Re: tap water with high TA
    Your tap water is quite similar in composition to ours. High pH also contributes to scaling. When you have a high TA and a high pH at the same time, then that's likely to be your problem.
    90k litres, outdoor in ground pool, concrete, painted (I hate paint)
    Sta-Rite 5P2R 1.5 Hp pump, undersized sand filter (needs upgrading).
    Jul 2012
    Riverside, CA
    51
    The ph is 7.5. Isn't it in the right range?
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Punch all your info into the pool calculator and check out the CSI it gives you.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    Jul 2012
    Riverside, CA
    51
    The csi is 0.27. Does it mean refilling with my tap water is ok and won't exacerbate the scaling?
    30,419
    Lower your TA down to 100. (see Pool School) Keep your pH no higher than 7.5 and watch your CH as it will tend to build over time.
