Results 1 to 9 of 9
Thread: Cyanuric Acid 200ppm - Drain Pool
    Jul 2012
    Fort Worth, TX
    9
    Pool Volume 16,000/In ground plaster/Inline Chlorinator. I used 32 oz of 6% chlorine yesterday and had Leslie's test water this morning. Of course, they said to drain pool 80% and/or replaster. We've never had these issues before and pool is 14 years old in full TX sun all day. They stated we should only use 1-2 tablets in chlorinator at a time, which may be the issue since we've always filled it and ran it at 4 for 9-10 hours a day.
    FAC 0
    TAC 0
    CH 200
    CYA 200
    TA 225
    pH 7.6
    Copper 0
    Iron 0
    I've heard you can add lye to help lower CYA, is this safe? If we add overnight with pump running will it be OK to swim next day?
    Fort Worth, TX
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    Re: Cyanuric Acid 200ppm - Drain Pool
    i thought the only way to lower CYA was with water replacement..
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
    Jul 2010
    England, UK
    156
    Adding lye will just make your pH go sky high, and then you'll have two problems to deal with not one.
    The only way to lower CYA is to drain part of the pool and replace with water that has no CYA.
    90k litres, outdoor in ground pool, concrete, painted (I hate paint)
    Sta-Rite 5P2R 1.5 Hp pump, undersized sand filter (needs upgrading).
    Aloha WilburFW
    PLEASE don't add any lye (sodium hydroxide) to your pool... I've never heard of that one...so I think there must be some sort of confusion going on...
    I agree with TOPHER and LOOP PEA...you should probably get rid of 3/4 of your pool water and refill it and just balance your water to have about 50 ppm of the CYA, and this will lower your alkalinity too (225 is WAY high for that).
    If you have any Caly Hypo shock, you can use that to chlorinate the pool at the start (dissolve it in a 5 gal. bucket over time and just keep pouring off the dissolved water from the top of the bucket), and it will increase your Calcium Hardness (you'll need to raise that after refilling the pool if your water isn't very hard--if you have hard water, you might be just fine!).
    Aloha!
    Warren
    Big Island Pool Service
    No pool of my own...but my customers' pools are ALL my foster babies!!
    Jul 2012
    Fort Worth, TX
    9
    Thanks! Didn't have a warm fuzzy about adding lye. Rather than emptying 3/4 of the pool at once we saw on a website to do a 1/4 at a time and then refill that, and in a few days repeat until appropriate level is reached. We have hard water so, hopefully, we'll be fine on the Calcium Hardiness. Going to try to start using the BBB method.
    Fort Worth, TX
    30,403
    You'd better start the drain/refill pretty quickly or get some chlorine in your pool. You will have algae very soon with your FC at zero.
    topher's Avatar
    Jun 2012
    136
    ive been doing the BBB method since I opened the pool this year. so far my only complaint is the fact I gotta vacuum the pool more often as I can see EVERY speck of dirt on the bottom of the pool and it drives me crazy. - yes it's dirt I live in a farming area there is a field 20` away from my pool and the tractors blow dust into it.
    i never had this problem in the past though.. but I guess thats cuz I could only see the bottom fuzzy like.... now I see sparkles on the white spots in my liner.
    Jul 2012
    Fort Worth, TX
    9
    Algae was what we thought our original issue was until the CYA came back high. Don't have recommended tester as I just found your sight today. We also live out of the city on two acres and have a "neighbor" building a house on the adjoining property, so lots of dust. We switched from DE to Fiber Clear and have that under control now. Had to backwash more frequently at first due to it picking up smaller particles, but better for us.
    Fort Worth, TX
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Problem with just doing 25% drains is its going to take ages to get the CYA level down, first time it will drop to around, 150, second time it will drop by 25%ish again to around 113ppm, then 25% on the third quarter drain to around 85, so that's 12,000 litres put in but only 43.75% of your pool water replaced (roughly)
    You need to figure out what your source water will do to the pool, TA/CH/pH, and go from there but with CYA at 200 you definately need to replace at least 50% of your pool water on the first drain to get it down.
    Stuart Murray
    Scotland UK
    UK NPPOC
