Thread: can't get chlorine level down!
    Sep 2007
    middle tennessee
    38
    having trouble with my chlorine leval,can't get it to come down enough..
    6 days ago my reading was about 21 i think with my taylor kit...
    drained about,, 1/4 of my pool water and put in fresh..also had a good rain..
    added 3-containers of MAJIC JACKS chlorine reducer..which says it should reduce it by,4 each..
    test today at pool store they read-11ppm..
    my test read 14ppm.....
    pool is uncovered and nice and clear..
    should not the all of that along with the sun reduced it more??
    pump runs 24-7.....
    Above ground 24'round-vinyl-14,000 gal,,1 speed-2 hp pump, 250 lb sand filter ..heated,,salted,,lighted,,decked,,with slide and pool rover jr.....
    TFP 100,,am doing the BBB thing...Wet is Wild!
    30,414
    I can think of no reason why you want to force your chlorine down. It will come down on it's own somewhere about 2ppm daily. Why do you feel you have to reduce it?
    And what is your CYA level?
    Sep 2007
    middle tennessee
    38
    Man,,you fellows know what you you are talking about.....
    I thought 21 chlorine was a ,,,,non swim level,,,
    and my cya level was,,50.......
    new numbers are,,,chlorine--8
    cya --40
    free chlorine--0
    ph--7
    cyanuric acid--20
    now that my chlorine is in the ,,close to acceptable range,,i'll start trying to raise
    the rest of my levels,,,then turn my SWG on,,done added salt...
    again,,,BIG THANKS guys.........
    Jul 2007
    Northern NJ
    299
    Those numbers aren't right.
    the FC should be 8, not 0. if CL is 8 and FC is 0, your pool should not be clear.
    CYA is cyanuric acid, so you can't have a reading of 40 for CYA and 20 for cyanuric acid.
    The pH is low. It should be between 7.2-7.6.
    You should run those tests again before adding anything else.
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
