Results 1 to 8 of 8
Thread: "dirt" on bottom of pool
    We have an above ground, intex pool... 20 x 4. Our water is clear but we cant get rid of the 'dirt'/sediment on the bottom of the pool. When we vacuum, it just blows right back into the pool, turnng the water cloudy. We are using the pump that came with the pool and a new filter.
    What can we do? Should we just vacuume to waste? Does anyone have this problem?
    Pls help, this is soooo frustrating!
    30,403
    Re: "dirt" on bottom of pool
    "dirt" is very often dead algae. Can you post a set of test results?
    th 200
    fc 2/4
    ph 7.2
    ta 120
    cya 30
    Vacuum to waste or buy a better pump/filter combo. I had the same issue with the Intex cartridge and bought the 1650 combo they offer and the problem is gone.
    try stuffing the center of the filter cartridge with a sock and put a sock over the output (we used a hair elastic to keep ours attached). Rinse them OFTEN, like every hour. Sort of a redneck way of doing it but worth a try.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Clean cartridges (std intex spun fiber type) actually let fines through better than a slightly plugged filter cartridge.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    I had luck with a cotton sock rubber-banded onto the return. Also, I think someone on here once posted that they put the filter in pantyhose - I've never tried that, but I think it is worth a shot.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Jul 2012
    NW FL
    91
    I have a 2 y.o. filter That works great for catching fine particles (dead algae, silt) but do not know the maker and have not been able to find any more like it... The ones that look like dryer sheets, are not effective IMO in filtering anything but big chunks, bug parts, tiny malformed acorns (about the size of lentils, smaller actually)... But I have had better luck with the unicel 4607... And boy do they rinse clean... The pool store operator I bought them from said they would rinse clean and last 2 seasons...so far she was right about cleaning. Hope they last like she said...(she may be among the more reliable store owners.... When I questioned her about cya she gave all the right answers!!) I have only been in her store 2x to buy filters --- have never done testing with her... But I am glad she stocks and recc that filter.
    Could you fill in the details about your pool? It would help others here to help you... Here's how
    pool-school/read_before_you_post
    Also, before I found the unicel I did "vac to waste" but since I don't have that as a setting on my pump/filter, I ended up doing that by siphon... Use the search box in the lowest left hand corner of this page for instructions how....because vac to waste does take a lot of water, I duct taped over half of the hole on the vac head, and moved the vac very slowly so as not to stir up what had settled.
    Some people here have used floc or clarifier for clean ups, but if used incorrectly they can cause a much bigger problem.... So, most here do not recc them... So weigh carefully the pros and cons if you lean in that direction... (again search and read up) It's tempting when you see a bottle on a shelf that promises lots of results That being said I have used it once (post vacation clean up) with good result...
    And lastly, most importantly perhaps, resign yourself to the idea it will likely take days to a week to get it all cleaned up if you don't have one of thse handy dandy sand, or other bigger filter systems.
    And brush, brush, brush.. Just took a toothbrush to the seams around the edges today.... Soooo glad I did.... With all the rain and lots of recent heavy use, prob stopped a future algae bloom if cl levels were to drop... Found some spots of ick... So, just because the water looks clean and your testing numbers are good, doesn't mean stuff won't be lurking, waiting for you to turn your back...
    It can be done with the smaller set-ups and be kept that way....you will just have to be vigilant with your testing, adjusting and cleaning.... Good luck!!
    ~6500 gal 18' x 52" easy set agp, 7th year
    Intex 2650 sand filter, chlorine
    TF100 Test Kit
    Becoming a TFP lifetime supporter and purchasing the TF100 is absolutely the best money I have ever spent! :-D
