Thread: Dedicated Cleaner Return - Circulation Question
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    My pool has three returns - two on the stairs and one along the side of the pool. The side return is setup for a Polaris with a booster pump and due to this has slightly reduced water flow relative to the stairs returns and has no directional eyeball due to the quick disconnect fitting for the Polaris.
    I know I can reduce the eyeball sizes on the stairs to increase pressure to the dedicated return - but that won't solve the issue of the lack of a directional flow. Is there anyone who makes an adapter that I can put into the quick release fitting that will give me the directional flow that can be removed when using the Polaris?
    Here's a couple of pictures of the arrangement of plumbing and returns to clarify things.
    The booster connection bypasses the chlorinator (which is not in use) using the smaller hose seen in the 2nd picture. The small pipe T'd off the stair returns is for the slide.
    Jul 2009
    Olney, MD
    218
    Re: Dedicated Cleaner Return - Circulation Question
    If necessary, you could just unscrew the polaris fitting and screw in an eye-ball? It isn't too hard because you should really only be hand tightening those types of connections anyway.
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by J20832
    That sort of defeats the purpose of the quick disconnect but that's a possibility I admit. I did notice yesterday that the 360 comes with an eyeball adapter for the quick disconnect so I'm going to see how much those are before attempting anything else.
