Thread: stains (pine cone and from screw driver bits) on my liner
    I did a search but could not find an answer.
    I have a vinyl liner and have a stain from a pine cone that was sitting there (my solar blanket was on when I went away for a few days).
    How do I get rid of them? They are in the deep end, of course.
    Second type of stain.... in a couple of spots a screw driver bit fell in and left stains in a couple of spots. The stains are sort of yellowish-brown. In the shallow end.
    Any ideas?
    I might try one of those Mr Clean magic erasers, which do wonders.
    Ken
    17,000 gal SWG pool
    Liner, 5 x Heliocol solar panels, Haywood gas heater, Super Pump II 1HP, Haywood pro sand filter, Haywood T cell-15, Pro Logic controller,
    Taylor test kit controlled pool
    Params - 5.0FC (if not shocking) ca-270, ALk-100, pH-7.2-7.6, NACL - 3000, CYA -60-70
    30,421
    Re: stains (pine cone and from screw driver bits) on my line
    Crush up some vitamin C tablets, put them in a sock and hold them on the screwdriver stain for a few minutes.
    The pine cone stain is organic and typically somewhat elevated levels of chlorine will fade it away within a week or so.
    Thanks David... I will try that. Ken
    17,000 gal SWG pool
