Thread: FAS-DPD test kit question
    Jul 2012
    Way north of Chicago
    40
    Prev owner left me a Taylor K-2005 test kit with a fair amount of juices left, but unknown age. This is like the good kit (K-2006) without a FAS-DPD setup. Question is, should I just buy a FAS-DPD test or should I buy a whole new kit? Do reagents go bad in a couple years time? If just FAS-DPD, is a Taylor K-1515 the appropriate kit? Anywhere to buy one locally near Gurnee, IL or in Milwaukee?
    Also, if or should I say when I start doing borax, guess I'll need borax test strips - ditto on the where to buy.
    Mange tusen takk for any help.
    25000 gal inground curved L shape - concrete, fiberglass walls - with Jacuzzi Sherlock 160 cartridge filter, Laars Lite LLG gas heater & Klean-a-tron robot
    near the pool: Cookshack Smokette, Akorn Kamado grill, putting green
    in the shed: Deere greens mower, Simplicity FC-16 front cut mower
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: FAS-DPD test kit question
    You can just purchase FAS-DPD test kits.
    TFtestkits.net is the best place to purchase. They have fast shipping and good prices. Here's the FAS-DPD from them: http://tftestkits.net/FAS-DPD-Chlorine- ... t-p47.html
    Here's Borate strips: http://tftestkits.net/Borates-Test-Strips-p29.html
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Reagents can and do go bad. Search for extended test directions thread, there see some bits of info there that help you decide if your chemicals are still good.
