Thread: Plumbing Questions
    Plumbing Questions
    I have a couple of question about the plumbing for the returns. They are plumbed with 1.5" PVC and connected as shown in the attached picture. The pool is 6' x 35' gunite pool (~28k gallons) with a 7' x 12' tanning ledge. The pump is a 2 hp variable speed.
    1. First, I was told that the returns would be plumbed in a loop, but this is how they were run. When I questioned the PB about it they said it would be fine this way because the eyeballs are 3/4" and will neutralize the line. Should the loop be plumbed in to help maintain the pressure on the returns furthest away from the equipment?
    2. The return at the top left of the drawing was run part of the way down the wall of the gunite shell while all of the others were run around the shell and just a straight section of pipe is sticking through the shell. I would think the last return should have been run the same as the others. I would think that you would want the minimum amount of piping/connection points inside the gunite, but I wasn't sure if this is acceptable.
    Thanks for the replies.
    Attached Files Attached Files
    30,426
    Re: Plumbing Questions
    You can equalize the flow by putting smaller eyeballs in the returns closest to the source line and then succesively larger as the returns get to the end. It is nice that you have so many and I think that would make for a satisfactory solution.
    I'm not sure I understand #2..... You are not saying there will be visible piping inside the finished pool, are you?
    Apr 2012
    Klein Tejas
    249
    I'm not sure why the plumbing didn't finish the loop. From a material standpoint he was almost there.
    Around here, it's common to have most of the plumbing inside the gunite. The cement prevents movement of the pipe and connections which could cause a leak.
    Pool is DONE!
    Pentair Intelliflo VS3050
    Pentair Easy Touch 8 + actuators + swg
    Pentair IntelliPH
    Pentair 400btu HD heater
    3- Jandy WaterColor LED's
    Hayward C5030 525sqft cartridge filter
    Waterway spa blower
    30,426
    Me, either.
    Thanks for the quick replies.
    No, there will not be visible plumbing in the pool. I just didn't know if it was common to have the plumbing run inside the gunite since they didn't do that anywhere else.
    Quote Originally Posted by bigdav160
    That was my thought as well. I didn't know if the eyeballs were going to be enough restriction to make sure that the returns at the end of the runs had sufficient pressure.
    Jul 2012
    Oklahoma City
    72
    From my research, I would want a closed loop, this will remove any possible controversy and you mentioned, it was as per the contract. Any pipes in gunite are more difficult to repair then pipes just below grass or decking.
    All just my 2 cents Good luck!
    IG gunite Edmond, OK(OKC), 18x36 freeform ~20K, 4-8' deep, Pentair equip, (2) 3hp VS+ pump, 520 cart filter, 3 LED, Easytouch8, ItellichlorIC40 SWG, Polaris 3900 cleaner, Spa 8'x18"raised, 20' raised bond beam 2 sheers, Stonescape Tahoe Blue quartz plaster, TF-100 kit.
    Feb. 25, 2014 dig started, May 24, 2014 filled.
