Thread: Vermaculite Finish Coat durability
    We're finally getting our pool taken care of, 18'X40' IG w/ Vinyl liner (although it doesn't have one at the moment.
    They are coming tomorrow to put in the vermaculite coat, before dropping the liner. However, it will be about a week between when they do the coat, and when they put in the liner.
    It's also supposed to rain that week. How bad is that going to be?
    It will not be bad, Vermiculite is a very high Psi form of concrete, once it hardens it is just like concrete. as long as it does not rain withing the first 18-24 hours it will be fine, the water will just run into the main drain, and could be sucked out with a vacume. Good luck, snap some pictures we want to see it!!!!
    17,000 gallon IG Humpback Kidney
    333k Sta-Rite Max-e-therm Heater
    Sta-Rite Modular Filter
    Intellichlor IC-40
    Awesome Tiki Bar!!!!!
