Thread: is it possible to use too much R-0870 DPD powder?
    Jul 2012
    Herndon, VA
    419
    is it possible to use too much R-0870 DPD powder? As in, if you use too large a heaping scoop, will that affect the FC reading, making it higher than it actually is?
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Jul 2008
    Seacoast, NH
    250
    Re: is it possible to use too much R-0870 DPD powder?
    No.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Jul 2010
    Philly
    332
    No but you can get inaccurate results from adding too little powder. A good rule of thumb is to add enough powder so that there's always a little bit of undissolved crystals on the bottom after that first initial swirl.
    Real high Chlorine levels need a little more powder so that there's some undissolved crystals left on the bottom.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
