Thread: Ph testing drops problem
    I have been testing with the TF-100 test kit all summer. I ran out of the red ph drops that came with the kit (R-0014) and ordered new drops that I thought were the same. The new drops are R-0004- to be used with the with 2000 Series(per label). The reading I got with the new drops was a ph that was in the hot pink red color and I know my level was about 7.4-as I just lowered my ph yesterday and tested this morning with old drops. Any dilution of the water trick I can do so I can use new drops?
    Kris
    In ground 26,000 gal. 16x36 Avg depth-6'
    sand filter used 24/7
    auto cover
    Elgin/Illinois
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Ph testing drops problem
    Looks like this is the answer you were looking for.
    http://www.troublefreepool.com/diffe...14-t19175.html
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Thanks!!!! I appreciate you posting that info-
    Kris
    auto cover
    Elgin/Illinois
