Results 1 to 20 of 20
Thread: No good deed goes unpunished ;)
    May 2011
    Southern NH
    18
    I'm on the second year of BBB started with a new pool - couldn't be happier, never had a problem, my pool is perfect (sorry for bragging). My neighbor and great friend has had a pool for 30 years, always had problems and has consistently been pool store'd and sick of his algae problems. When he asked about my pool and what I do (never gave him a hard sell) He bought a TF-100 and everyone in his family is so excited about his sparkly pool.
    My problem: Now I get to be the expert in clearing his brother-in-laws swamp. I'm getting a bunch of info second hand. He's spent $800 this season, trying to clear it(I didn't even ask what he's been sold). I have no experience in swamps, but I'm confident I understand the basic chemistry.
    Numbers reported in the text asking for help tonight: 27 ft round AGP - estimated at 18,000
    CYA 0 PH 8.2 FC 1.0 CC 1.0.
    I don't have a lot of free time. I plan to win. This is my punch list, please give me feedback:
    #1) get the pump on 24/7 and make sure he monitors the pressure/backwashes when necessary.
    #2) retest CYA - they have 12lbs of dichlor on hand, if it is truley 0, I plan to add 6lbs, retest (when?) and then adjust if necessary
    #3) reduce PH to 7.2 - has 5lbs of "lo and slow" on hand - not sure of make, etc - but will target 50% decrements and restest until target is achieved.
    #4) we brush the entire pool. He does it at least once a day until the crisis is over.
    #5) add CL (figuring in #2) to bring to shock level (CYA chart)
    #6) repeat testing/adding every hour for the first 6 hours.
    #7) Continue procedures until the 3 shocking criteria are met
    Am i missing anything?
    Thanks!
    24000 Vinyl. Hayward: DE Pro-Grid 3620, 1 HP SP2607X10
    250k H250FDP Propane Heater
    Booster pump 6060 w/ Viio Turbo Cleaner
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Re: No good deed goes unpunished ;)
    Looks good to me except I would want to know what he was sanitizing it with. May help you in the long run. If tabs then the CYA number may be wrong, if Baquacil then you know you have a huge amount of chlorine to continue adding. Otherwise, good job being a helper. You can usually recoup favors like when you go on vacation and you need your pool looked after.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    May 2011
    Southern NH
    18
    Awesome!
    #0.5 - question what he's been doing to date.
    I Love this forum, this is why I'm not afraid to ask for help!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Looks like a good plan to me too.
    Mar 2012
    Amarillo, Texas
    341
    nhguy,
    I'm going on vacation next month and my pool's not a swamp. Would you take care of it for me? LOL.
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    If the guy's already spent $800, he might not balk at the easiest solution: drain it all and start from scratch. 'long as it holds water and the filter works, you'll have him sparkling in a couple days. Maybe a little longer, if it takes a long time to fill..
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Swamps take time and can be seriously frustrating... but your plan looks good.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    May 2011
    Southern NH
    18
    Thanks Richard - definitely going to keep that option in mind. I haven't seen the swamp yet - I should get over there about 11:00 AM tomorrow after the jimmy fund cancer fund little league tournament finishes.
    May 2011
    Southern NH
    18
    mpacheco72 - I do not have time for you.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Quote Originally Posted by nhguy
    The commute would be brutal.
    Mike
    May 2011
    Southern NH
    18
    Thanks for your support dattia! That's what I'm worried about that that I'm somehow the "expert". I promise to post before/after pictures of this ordeal....
    Jul 2010
    Philly
    332
    If your using DiChlor make sure you test PH and TA first. If his CYA is really 0 then 12 lbs of DiChlor will give you 40 ppm of CYA. The first 6 lbs, depending on his TA will lower his PH almost a full point so leave it at 8.2 If it's not, adjust his PH on the high side. I also would make sure his TA is at least 100 because that's going to go down 20 or more.
    Other than that it looks like you have a good plan in place. Good on you for paying it forward. That's a very nice gesture on your part.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
    May 2011
    Southern NH
    18
    Awesome! Thanks for very helpful advice! Please don't be shy to chime in. I'd like to dispose of this project as quickly as possible!
    Mar 2012
    Amarillo, Texas
    341
    No time?
    18'x48" AG
    Hard Plumbed
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    I didn't see a CH result. If CYA is truely 0 then they may have been using cal-hypo all this time and the CH would be very high. When you make your first visit, look through the chems he has, write down what they are and the main ingrediants. Find out how often they use them and take pictures of it, the pool and the equipment pad. Run a complete set of tests with your kit and post results here. We will be your cheerleaders/back seat advisors while you tackle this project!
    Love TFP? Become a
    TFP Supporter!
    May 2011
    Southern NH
    18
    Things going well. Started sat morning 10 am. Wasn't quite a swamp, but couldn't see bottom of 4 foot pool, ick! PH now down to 7.2, cya is up to 20 (using dichlor on hand). CH is 120. He's testing hourly during the day (already bought a tf100 and speed stirrer!). He already had went out and got 14 gallons of 12.5 click, on his brother in laws advice. He's adjusting with 12.5 liquid only keeping greater than 10 cl (I told him keep it a couple higher assuming some cc) . Only brushed once, encouraging him to do at least daily. He's staying on top of filter pressure.
    He seems really into it and he's encouraged that it's lightening up a bit already .
    I'll keep updating, thanks for the support!
    Also, make sure there is no debris in the pool. Push a leaf rake around a bit, or run the vac, just to see if anything comes up.
    DCAG's Avatar
    Jul 2009
    Merrimack, NH
    95
    This seems like the Southern NH thread... so I just wanted to say... Hi!
    16' X 24' Wilkes Pools "Genesis", 10K Gal
    Hayward Powerflo Matrix 1 hp, & 18" Pro Series sand (S180T)
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Quote Originally Posted by DCAG
    Hi neighbor.
    Mike
  20. Back To Top    #20
    May 2011
    Southern NH
    18
    Howdy neighbors!
    Quick update, he seems to be keeping up with it (testing, adjusting, backwashing, brushing). Progress is as expected : it's lightening up, still really cloudy.
