Thread: Finally received my TF-100, first numbers...
    Hi everyone...
    I'm new to the fourm and have been lurking here for a few weeks. I must say that I'm addicted to this site and the info here great! We are new owners of a 15 x 54 round, vinyl pool and from day 1 are using the BBB method. I just competed my first test with my TF-100 and here are my results for critique/advise....
    My FC is 1.5, I would like it to be 5 based on the recommended levels info in Pool School
    My CC is .5 with my TC being 2.0.
    My TA is 80 ppm, which is what I was shooting for based on the 70-90+
    My CH is 140, I was thinking 200 would be more ideal...
    My CYA is 20 right now, I am shooting for 40....
    Any suggestions or recommendations are welcomed!
    Thanks!
    15ft x 54in AGP/Vinyl
    ~5,950 gals
    1.5 HP Sandman Cartridge Filter
    BBB Method
    Mar 2012
    Amarillo, Texas
    341
    Re: Finally received my TF-100, first numbers...
    Don't worry about your CH since you have a vinyl pool. Raise your CYA and boost your FC. Otherwise I think your numbers look great!
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, boaz65
    Quote Originally Posted by boaz65
    For 20 ppm cya, poolcalculator.com gives me 2-5 for normal FC range, so try to stay above 2.
    No need to do anything with CH. Low CH is not a problem for vinyl pools, high CH can be, but yours is low so leave it.
    How are you adding it? If it is the granular type, then it can take a week to show up on test.
    Thanks for the welcome everyone and the info! To boost my CYA, I have a bottle of HTH Stablizer (white powder) and I'm only using store brand liquid bleach (6%) to control my chlorine...
    ~5,950 gals
    BBB Method
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
