Thread: Pebble Fina questions
    Mar 2009
    Glendora, California
    169
    So I thought I was decided on Pebble Sheen, but one of my quotes came back with Pebble Fina as the least expensive of the three (Fina, Tec, Sheen) even a tad cheaper than quartz. I love a bargain and am wondering if I have stumbled upon one. I am fine with the finish of either but was wondering:
    - Is Fina as long lasting as Tec and Sheen?
    - Is Fina as resiliant to poor chemistry like Tec and Sheen claim to be?
    - Is Fina as resiliant to stains like Tec and Sheen claim to be?
    The second and third points concern me the most as I can get lazy in the off season and my current plaster has rust stains and what I think is a metal stain. I also understand that point two has an effect on point one.
    18k Inground Plaster pool / TriStar Variable Speed Pump and Controller
    48sq ft Hayward DE filter/ Swim pure Plus 40k cell / Kreepy Krauly
    Solaxx Ph-Tek
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Pebble Fina questions
    Well....I have first hand experience with this one. I can personally attest to the durability of the Pebble Fina. We purchased a bank owned home with a neglected pool. The color which basically looks like white plaster but is has some definite "fleck" to it. See signature line. I had a 4" rust stain and it came out with some vitamin C tablets but as you can see, it cleans up well. I am impressed with the finish for a number of reasons:
    1. Sat nearly empty for a while with no damage
    2. Cleaned up well
    3. Looks great when filled (with clean water of course)
    I would be interested to know if there would have been different results if it was regular plaster. It will also depend on what color you choose to what you can get away with...although you should take care it the right way regardless.
    Before:
    After:
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Jul 2011
    Arizona & California
    805
    All of the Pebble products are excellent and more durable than regular white pool plaster. Fina is fairly smooth. Sheen and Tec are bumpy. All three products also use regular cement as the binder material. The cement can be compromised and can be affected by improper water chemistry, rust stains, and improper workmanship issues. Scale can develop on all three finishes, and the cement portion can be etched by aggressive water. Improper chemical start-ups, and improper workmanship, such as adding too much water to the mix, or adding too much calcium chloride (accelerator), can cause a whitening affect to appear within a couple of months. Reading "Ten Guidelines to Quality Plaster" in this Under Construction section provides further information. ten-guidelines-for-quality-pool-plaster-t42957.html
