Thread: Jandy Check Valve Socket Depth
    Jul 2009
    Long Island, NY
    267
    I am planning a plumbing modification and need to know the socket depth for a Jandy 2/2.5" straight check valve. I found a post on the forum which shows the overall valve length as 6.5" but also need to know the depth of the pipe socket on each side.
    Thanks.
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    South Central NJ
    3,192
    Re: Jandy Check Valve Socket Depth
    Inch and a quarter on each side. Since the check is 6.5", cut a 4" space.
    Scott
    Owner of - PoolGuyNJ LLC
    Jul 2009
    Long Island, NY
    267
    Scott,
    Thanks for the reply. I was going to install the valve this morning but a bad thunderstorm came through. Maybe it will clear up later and I can get it done.
