Thread: Spa make-up return
    Jul 2012
    Austin, TX
    75
    Spa make-up return
    Hi,
    I am re-doing my plumbing and have a question about Spa make-up return.
    In page 2 (Basic Pool & Spa Combination Plumbing) of this link
    http://instantpoolparts.com/manualfi...Schematics.pdf, there is a jandy valve and a check valve right after the heater.
    I am wondering if I can remove that make-up loop and use the existing 3-way valve to control the spa make-up return. Can I just leave that 3-way valve slightly open so that some water can flow to Spa return? Of course, I will install a check valve in the SPA return line. In my proposed setup, I can save a 2-way jandy valve. Any comments?
    Lazy-L shaped pool and a spa. 22.5k gallons. Pentair VS pump. Pentair cartridge filter CCP520. STA-Rite SR400NA heater (400K BTU). Leuder limestone coping. Pebble sheen (blue granite) Wooden deck.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Spa make-up return
    That's the way mine is plumbed. No spa bypass, I have to set it manually.
