Results 1 to 10 of 10
Thread: uniform depth liner dished out bottom!
    Hello,
    Can I dish out the bottom of a pool that comes with a standard uniform depth liner (20mil liner)? I was thinking off 12inch max.
    Buried oval above ground pool, 12x24, 7000gal
    Using the BBB method
    Sand filter 45kg, Pump 1000gph.
    Living in Portugal, Europe.
    Re: uniform depth liner dished out bottom!
    Sorry it is a 16mil liner that comes with the pool.
    So can I stretch this liner to get some extra dept in the pool without having the risk of tearing it?
    poolgranny's Avatar
    May 2012
    Mid-Missouri
    120
    I am not sure -- but they ones that can your question may need more info --
    Size of pool? Depth? Type of pool if you know?
    Above Ground Pool 15' by 30' Older pool -- Make ? Model ? Cost - Free; Given to Us
    Gallons approximately 11,000 (if I figured correctly)
    New liner in 2007 when pool was moved and installed by son-in-law and family members
    Hayward Sand Filter 150 pounds of sand (purchased new in 2007)
    White River 2 horsepower pump (purchased new in 2012)
    Deck built in 2011
    Bioguard 1200V Multi-Test Kit with an additional Orthotolidine Chlorine Test Kit
    It is a oval pool with 3 straps, I will be cutting 2 off them and dig them in and attach a cement block to them like in this post: pool-under-construction-t34670.html. The pool is 24feet by 12 feet and 4 feet high. I only will be digging the pool out by max 12inch. IŽam gona digg the pool in so I have an inground pool.
    The liner is an overlap liner.
    Netwit2008's Avatar
    Jul 2012
    Land of Oz-Kansas
    12
    I think what you need is an expandable liner. From what I've seen, if a pool has differing depths, this is what you get. Just check with any pool supply store and I think this is what they will recommend. The liner is designed to expand to cover the deep end. Also make sure you have researched burying an above ground. I read on another pool supply site (I've been doing tons of research looking for a replacement liner, lol) that if you bury an above ground, it may accelerate your rust/corrosion on the walls and actually make them unstable.
    I hope this is not too late to be of help. Good luck!
    Sharkline Reprieve 15' x 48" round AGP- 4,440 gallons (2012)
    Waterway 19 inch sand Filter (2011)
    1.5 HP Pump (1997)
    I live in Europe and it is very difficult to get an expendable liner here and also expensive because off shipping.
    IŽam really interested in knowing what a standard liner can stretch. IŽam not interested in a deep end but more in some extra depth like a bowl shape max 12inch. Maybe some people white some more experience can help me? How far can I stretch I standard 16mil liner?
    1/3 off the pool is left standard with a water hight off 41inch the other 2/3 off the pool will be dig-de out in a bowl shape with a max depth off 52-53 inch off water hight.
    Is there some one that have done this with a uniform depth liner?
    poolgranny's Avatar
    May 2012
    Mid-Missouri
    120
    I would be afraid of the seams of the liner pulling apart. It might stretch some, but over time it would seem to me the stress on the seams would be enough, along with the sun and chemicals that your liner probably wouldn't last too long.
    If it were me and I was only wanting to go another foot or so -- I would either forgo the extra depth or bite the bullet and get an expandable liner.
    Is there a specific reason why that extra foot is so important? If so why not purchase a deeper pool in the first place?
    Deck built in 2011
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    My understanding is the only liners that are expandable are the overlap liners and you need to stretch them into the pool. If the liner has a bead (j-hook, uni-bead) it cannot be stretched. My pool store only sells Doughboy brand overlap liners for expandable pools. I have never heard of cutting the straps on an oval pool. I have heard of making the deep-end start at the last strap and go deeper from there.
    Good luck.
    -- Guy --
    Here is a example how you can cut streps off on oval pool: http://www.propools.com/instructions_ow ... dliner.pdf
    poolgranny's Avatar
    May 2012
    Mid-Missouri
    120
    We have an oval pool and I would be hesitant to cut the straps.
    Except for that example, how many others have cut their straps and did a dished out deeper end?
    Deck built in 2011
