Thread: Maybe a wet suit is a good solution!?
    I was just thinking of how I might be able to extend the swim season. I will likely use my heater a bit more than I have in the past, but at certain temperatures it just isn't as enjoyable to swim. I know plenty of people likely have wet suits for scuba, but does anyone use a wet suit to swim in their pool when it gets cold? If I'm ok swimming in 84-86 degree water when it's 85 outside, would I be comfortable in a wet suit swimming in 65-70 degree water when it's under 80 outside?
    I found a NeoSport 5mm full wet suit on Amazon for just under $150 shipped. I'm assuming this is a reasonable price.
    Thoughts/opinions?
    Thanks.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Maybe a wet suit is a good solution!?
    Just be aware that frequent use will degrade the wetsuit.
    Here's a link:
    http://www.wetsuit.com/New_Wetsuit_Care_and_Repair.html
    Notice that if you are frequent user you might get 100 days use before needing repair.
    Excellent - this is great information! If I get two years out of it than I'm doing good.
    Aaron
    Aug 2011
    Virginia Beach
    295
    I don't know if you're anywhere near an Ollie's, but they had some on the shelf in Norfolk VA yesterday for $14.99. Bodyglove brand, maybe? I'm not 100% certain, but it was a brand I'd heard of before.
    http://www.olliesbargainoutlet.com/
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
