Results 1 to 14 of 14
Thread: Getting my TF-100 Today! Will post results later!
    Jul 2010
    Jacksonville, NC
    35
    Woohoo
    24' X 54" Sharkline Matrix. J-Hook liner.
    2 speed pump, 16" Intex sand filter.
    Sep 2009
    Greentown, IN
    914
    Re: Getting my TF-100 Today! Will post results later!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Jul 2010
    Jacksonville, NC
    35
    i have not added my daily bleach as of yet. Should i add before or after the CYA test?
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Might as well wait till you have all the tests done, unless you think the FC may be low.
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
    Jul 2010
    Jacksonville, NC
    35
    low.... HA
    used the whole tester bottle and still could see the dot.....
    Jul 2010
    Jacksonville, NC
    35
    ok so it says to add 27oz. of CYA. Cups would be easier,,,
    every converter i see says its for fluid oz.
    Would I use the vol. reading then, on the pool cal.?
    I have the pebble "stabilizer" from Lowes...
    Feeling so stupid right now...
    LOL
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Yes, if it's powder CYA, use volume. Looks like you're trying to raise the CYA by 40. Assuming you don't have an SWCG, it might be a good idea to start with 30. If you over shoot, only way to get it back down is partial drain/refill.
    Please post a full set of test results when able: FC, CC, pH, TA, CYA.
    Jul 2010
    Jacksonville, NC
    35
    CYA - 50
    PH - 8.2
    TA - 230
    CHLORINE - .5 - haven't done my bleach for the day yet.
    38,299
    You are letting the chlorine drop WAY too low. In normal (non-shock) mode, with a CYA of 50ppm, your FC should NEVER drop below 4ppm.
    You also need to get the pH back into the mid-7s, to avoid scaling problems.
    What is your CH level?
    What are your FC and CC levels?
    Jul 2010
    Jacksonville, NC
    35
    will do now...
    What to do first? Or, will that be based on the next tests?
    38,299
    Lets see the full results ...
    Both the pH and FC are pretty high priority.
    Jul 2010
    Jacksonville, NC
    35
    fc- 1
    cc - 0
    tc- 1
    ch- 70
    38,299
    How does the water look?
    At a minimum you need to get the pH down using acid and the FC up and staying above 4ppm. You can make these adjustments about 30 minutes apart by slowly pouring the chemicals into the pool in front of a return.
    You will need to keep a close eye on the pH as the high TA is going to tend to pull the pH up.
    You should likely bump the FC up close to shock level (20ppm) and do an OCLT to be sure nothing is living in the pool or to find out if you should go through the shock process.
    Jul 2010
    Jacksonville, NC
    35
    Crazy but the water looks better then before I found this site...Clear...
    ..Will do...
