Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Looks like pump is losing it's prime. Leak?
    Jun 2012
    Malvern, PA
    17
    Hi,
    I've recently bought a house with a pool. About a week ago or so I've noticed that when I turned filter on, the pressure gauge wasn't going up and stayed at 0psi whereas I think it went right up before. I had similar issue before where pressure wasn't 0psi but it was low and ended up finding out that air got in due to low water level. That made low pressure and previous owner helped me find out that's what caused it and used air relief valve to let air out and it was back in business. I wasn't sure what was going on so I tried that and after about 30 seconds or so opening air relief valve, I saw water coming up through strainer lid. I figured that was it and kept timer on.
    Couple of days later I turned filter on manually since I was home and wanted to use the pool earlier than usual time. As soon as I turned it on, 0psi again and I had to do exact same steps I took last time to get it going again. At this point I figured something was going on. Since then I've only kept OFF switch of timer and took out ON switch so it won't turn on by itself when I'm not home and be on with 0psi for hours.
    While checking out the pump, I've found a leak from one of seam. it's slow but it's noticeable so I figured if it leaks, it can suck in enough air when it's off through that to loose prime? Am I correct to assume this? Also I could be wrong but I think pump wasn't making faint whining noise but it does now when it's on. Maybe I just need to replace gasket? or even worse to replace the pump?
    This is picture of label that I took from pump.
    I can't post picture of where the leak is as I'm at work now but I think where I'm pointing with arrow are the area where leak is. First I thought it was other one next to it(like flange?) close to the strainer lid but it doesn't seem like it's that.
    Any help would be appreciated.
    South Central NJ
    3,192
    Re: Looks like pump is losing it's prime. Leak?
    I am guessing you have a Hayward SUper Pump or a Super II. What you are showing is indicative of the seal set needing to be replaced Its either that or the seal plate that needs to be replaced, in which case, the seal set is replaced anyway.
    Scott
    Owner of - PoolGuyNJ LLC
    Jun 2012
    Malvern, PA
    17
    Thank you very much for your reply.
    That's what I kind of guessed. Should I be concerned about whining though? Like I said before, it could have be just there that I just didn't care to listen for it till just now.
    I'm assuming I have Super II since I have round strainer looking at this page to reference?
    http://www.aqua-man.com/row_num.asp?Ic=1124
    I've checked Seal Plate for Super II and there's 2 different models? One for before 1987 and one fore after 1988? How can I tell which one is right for mine.
    If it is after 1988, I'm assuming it's this?
    http://www.amazon.com/Hayward-SPX302...words=SPX3020E
    But this says it's for 2.5hp-3hp model and mine isn't?
    Also, seal set you were mentioning would be this?
    http://www.amazon.com/gp/product/B00...7A83VWC6BTXVHT
    Would I need any other thing to go with this such as lube or other sealant?
    Bonus question: I didn't look hard but I think only label I saw was one that I posted earlier. How can I tell exact model of my pump?
    South Central NJ
    3,192
    Determining when simply means check the impeller. If it's an SPX2600 series impeller, the seal plate is an SPX3000E and if it's an SPX3000 series impeller, it's and SPX3020E Seal Plate. These are Hayward part numbers.
    The seal set for the Super II is the same for the Super Pump.
    Scott
    Jun 2012
    Malvern, PA
    17
    I've looked in to this further and found SP2810X15 which I think is Hayward MAX-FLO - SP-2810X15
    I've found diagram below.
    The leak that I saw was between motor mounting plate and motor but not between seal plate and motor mounting plate. I'm not sure if there's seal kit for this one though looking at the diagram?
    South Central NJ
    3,192
    Same seal set.
    Jun 2012
    Malvern, PA
    17
    Thank you very much for your help so far. I'm ordering gokit2 now. One more question is that does it leak between motor mounting plate and actual motor when that seal kit fails? I mean the seal kit is on the other side of the motor mounting plate.
    Apr 2009
    Northern Virgina
    55
    The go kit contains various o-rings and the motor shaft seal (which is labeled as seal assembly in the diagram above). If the motor shaft seal fails, then water will leak between the motor and the seal plate. Replacing the shaft seal and o-rings should solve the leaking problem you describe, but I don't think it accounts for your pump losing prime. Unless you saw enough water leaking out of the wet side of the pump (when it was not running) to drain the water out of the pump strainer basket, then the two problems are likely unrelated. Are you able to maintain the proper water level at the skimmers? If not, then you may need to investigate the possibility that you have a leak somewhere in your pool.
    As for replacing the shaft seal, if you have a heater or a salt water chlorine generator, make sure you get proper seal for this type of application. There is a great video on ussealmfg.com that shows how to properly replace a shaft seal along with information on selecting the proper type of seal for your pool. There is also a nice website with step-by-step instructions at: http://www.inyopools.com/HowToPage/how_ ... _seal.aspx
    22k gallon IG Anthony free-form pool and spa with PebbleSheen finish, Pentair WFDS-8 WhisperFlo Full Rated Dual-Speed 2HP pool pump, Sta-Rite S8D110 System 3 Grid D.E. 53 sq. ft. pool filter, Raypak R406A 399K BTU cupro-nickel propane heater, Polaris 280 pool cleaner with 3/4 HP PB4-60 booster pump, Goldline Aqua Plus controller and SWG, Inter-Fab G-Force pool slide.
    Jun 2012
    Malvern, PA
    17
    Hmmmmmm That's not what I hope to hear(don't we all) It has noticeable leak when pump is running which I have not run it for couple of days now till I replace the seal. I've just tried to clean leaves and other things as much as possible and just dump some liquid chlorine to keep it sanitized. It does not however that I have see so far have leak while pump is off. I figured since it leaks, it would have enough opening to suck in air over night(it used to be off at 9pm and on at 2pm=17hours total) and that's why it's losing prime.
    It seems to have little low water level but I figured between leaking while pump running(not much to make difference in water level though) and high temp, that would cause low water level.
    hmmmmm This is getting little more confusing now.
    South Central NJ
    3,192
    Seals sit between the impeller and the seal plate with the motor shaft running through the middle. The don't normally leak when the motor is off.
    Scott
    Jun 2012
    Malvern, PA
    17
    Well, I got GOKIT2 installed although housing gasket seem about 1/2" too long. I've still managed to put it in and it's all good. Pump lid O-ring how ever(Strainer gasket?) was way too big so I couldn't use it. Everything went well and no leak. But you know something had to go wrong. When I put everything back together, I mounted capacitor which inyopools who I used their instruction didn't mention about wires need to be tucked under capacitor. The wire must have caught metal piece in center which spins and yanked it out of it's place. now I have one metal piece and to springs that I'm having hard time figuring out where it goes.
    22,551
    Search here for centrifugal switch and you'll find a picture of how it looks.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Jun 2012
    Malvern, PA
    17
    Got it!
    This is the picture I've found and it looks like I have to mount flat side away from body of the motor and attach 2 springs on latches on side. One of spring is little stretched but I assume it's ok for now.
    I'm thinking I need a new motor eventually since noise will get worse but I figured we only have a month or so before it gets too cold to swim. I figured instead of buying a new motor only to stop using it and let it stand out in harsh weather, I will buy new motor when I open the pool. That way, I get good use out of the motor before winter time.
    That brings which motor I should get. I've seen it's better to get energy efficient ones and dual speed etc. Which model would be good candidate to replace considering fit, power etc? I've read that those model might cost little more initially but pays itself in a year or two.
    Thank you very much for all the help so far. Now I can change out seal without even looking at the instruction!
    22,551
    A 2-speed motor will be a good investment.
    Jun 2012
    Malvern, PA
    17
    Well, it seems my plan won't work. Motor is getting too loud that I can't turn it on during night time and even day time is pretty loud.
    Can you recommend power efficient motor that I can just bolt on based on information that I have provided so far with current motor?
    I looked around before and found this
    http://www.amazon.com/A-O-UST1152-2-...eywords=st1152
    Which I think I need 1.5hp model? Picture I took shows 1.5hp but total says 2.2hp?
    This one is sold by amazon and looks same model but more expensive?
    http://www.amazon.com/Smith-ST1152-1...eywords=st1152
    but my motor looks like this with ting on top of motor?
    http://www.emotorpro.com/112hp115230...or-st1152.aspx
    Would this work too? I mean this is cheap compared to others
    http://www.backyardpoolsuperstore.co...ed_p_4318.html
    I don't think any of motor I've shown are dual speed or power efficient model. Can you please specify exact model so I can shop around and buy it as soon as possible?
    Again, thank you very much to everyone who have jumped in to help me so far!
    22,551
    The 2-speed model of the ST1152 is the STS1152R. Locke Well Supply has the best price I found.
    Jun 2012
    Malvern, PA
    17
    Will that be direct bolt on? just disconnect existing wires and connect it back? I'm asking since it's 2 speed and figured it might have different hook up?
    Jun 2012
    Malvern, PA
    17
    Also, it shows it's 40c' amb temp vs current one at 50c'. Is this like max safe operating ambient temp? If so, it might be too close to some max temp here in PA?
    And service factore on 2 speed is 1.3 vs 1.47 on current one?
    22,551
    It is a direct bolt on but it uses an extra wire for the second speed, so the wiring will have to be changed.
    40C should handle pretty much anywhere in the U.S..
    The difference in SF is not a problem.
  20. Back To Top    #20
    Jun 2012
    Malvern, PA
    17
    Would it be pretty straight forward change to wiring that someone can do it with instruction or is it something that I would have to hire an electrician to do it?
