Thread: Cracked Floor
    Dec 2010
    Massachusetts
    50
    Cracked Floor
    Hi all,
    I have a crack on the deep end where the side meets the bottom of my 2 year old pool. PB has agreed to pull the liner an drepai rin the fall. It also appears there are smooth lumps/mogules going down one side of the decent into the deep end. They span about 12in in size.
    Anyway, the PB used concrete with fiberglass mesh to pout the base. No rebar or steel of any sort to reinforce. Should he have used the rebar?
    Thanks
    South Central NJ
    3,192
    Re: Cracked Floor
    I never seen rebar reinforcement on the floor or hopper walls for a liner pool.
    Scott
    Owner of - PoolGuyNJ LLC
    Dec 2010
    Massachusetts
    50
    Re: Cracked Floor
    PoolGuyNJ,
    What do you use on the floors, hopper walls?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Cracked Floor
    dholland17 , it would be helpful to know your location.
    You can add your location in you profile: Go to "user control panel" top left, under TFP logo, then select 'edit profile'. We thank you
    You're done SLAMing when:
    Dec 2010
    Massachusetts
    50
    Re: Cracked Floor
    Massachusetts
    South Central NJ
    3,192
    Re: Cracked Floor
    Liner pool bottoms can be sand, cement, or vermiculite and cement. Few use sand anymore though.
    Scott
