Results 1 to 10 of 10
Thread: First Time Pool Owner Confused About Free Chlorine level
    Hi guys,
    This is my first time owning a pool. I went to Leslies Pool Supplies and bought some "dichlor" Chlorine granules. It is stabilized chlorine. On the bucket itself, it tells me to maintain a free chlorine level of 1-3 ppm, by adding 3 ounces of the chlorine per 10,000 gallons every other day.
    However, this is stabilized chlorine, and my CYA level is 60. I went to poolcalculator.com and it recommends a free chlorine level of 5-9 ppm based on my CYA level. My question is why would the bucket of chlorine tell me to stay at 1-3 ppm if they made it and know it's stabilized chlorine and the CYA level will rise? Should I listen to the instructions on the bucket or the poolcalculator.com website?
    Thanks very much for your help
    4,500 Gallon above ground
    Cartridge Filter
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    Re: First Time Pool Owner Confused About Free Chlorine level
    Hi Penn,
    A lot of people even in the industry don't understand how CYA really works. The traditional method is just to keep your FC at 1-3 ppm and ignore the CYA. In my experience you will get much better results following the poolcalculator.
    Quote Originally Posted by Christian
    Hi Penn,
    Thanks for the response Christian. I am just afraid of burning myself using so much chlorine and I don't want an unpleasant experience. My water has been crystal clear and doesn't smell like chlorine following the instructions on the bucket and maintaining 1-3 ppm, but this poolcalculator.com has got me thinking I should listen to it to prevent future problems. Like I said I just don't want to put too much chlorine in the pool
    Cartridge Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    "Too much chlorine" would be something in the neighborhood of 20 ppm. Which might fade your swimsuit but probably wouldn't do much to you unless you have sensitive skin.
    What you don't want is too much CYA. And you will have that if you use that whole bucket of dichlor.
    I suggest you do a bit of reading in Pool School. Or peruse the threads here. You'll find a pretty good correlation between threads with "cloudy water" or "Won't clear" or "Green pool" and high CYA levels.
    Christian's Avatar
    Jul 2012
    304
    Yeah it may be clear now but it won't stay that way if your CYA gets out of control. And remember that the CYA buffers the chlorine from the water so what may seem like a high level is actually perfectly normal.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, pennjersey83
    Good news is your cya is not too high yet, though our recommended range is 30-50 ppm (assuming you do not have a saltwater chlorine generator (swg)), you can manage at 60 ppm. Definitely do not use anymore dichlor. Take a look at this pool school article: http://www.troublefreepool.com/pool-..._chlorine_pool
    How does your water look?
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    First off stop using stabilised chlorine, you are already above recommended levels, keep it for use when your CYA levels needs topped up due to backwashing, and switch to either Sodium Hypo (bleach) or Calcium Hypo, depending on your needs, read about the pros and cons of both in pool school, generally though for residential pools it's Sodium you should plump for.
    Higher chlorine levels 3-20ppm are not any concern in residential pools.
    Regards
    Stuart
    Stuart Murray
    Scotland UK
    UK NPPOC
    Quote Originally Posted by Richard320
    Quote Originally Posted by linen
    Sounds good I'll read pool school and buy non-stabilized chlorine. My water looks great and I want to keep it that way. All my readings are good except the CYA at 60. Thanks guys I appreciate your help
    Cartridge Filter
    Just finished reading pool school. Also loving the pool calculator! Man I wish I knew about this stuff weeks ago.
    Cartridge Filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by pennjersey83
    Make it your best friend
    Even that is not bad, quite managable by just maintaining a slightly higher minimum FC, now if it was at 90 ppm, that would be another story.
