Results 1 to 19 of 19
Thread: How long did your SWG Cell last before replacement?
    iggy's Avatar
    Jan 2008
    The Cool Part of Arizona
    175
    I was just curious if the SWG decrease production over the years.
    I have one that is 4 1/2 years old and seems to put out less than it did when new.
    Should I start looking for a new one?
    How long did your Goldline/Hayward SWG Cell last before you replaced it?
    In-Ground SWG pool 11,000 gal., Jandy CL460 Filter, 1.5hp Stealth Jandy pump, Paramount PV3 In-Floor cleaning sys., Goldline SWG, Hayward Color Logic 2.5 LED Light
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    Re: How long did your SWG Cell last before replacement?
    Hi Iggy,
    Have you tried soaking it in an acid solution? In my experience it shouldn't decrease output like you are describing unless there is an issue with calcification. The average life for a t-cell is 3-5 years. The longest I've ever heard of one lasting was about 7 years.
    iggy's Avatar
    Jan 2008
    175
    Quote Originally Posted by Christian
    Hi Iggy,
    I clean mine when needed. I just asked as it seems that I have to increase my percentage of time on to get a set result of chlorine.
    I was just wondering how long they last. 7 years is really along time. I'm planning on finding a replacement and maybe keep this one as a backup.
    Thanks
    Aug 2009
    SW Wisconsin
    518
    you need to take it out and inspect it for scaling and build up...if it has some, you'll need to clean the cell with muriatic acid. My unit is a self cleaning model..but I still take the cell out and inspect it each season. I am on 4 seasons now with mine and still going strong.
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    mas985's Avatar
    Pleasanton, CA
    11,737
    August will be my 7th year. I am starting to see some decrease in output as well although there are other factors that can contribute to that. For the same cell size, theoretically, a smaller pool should have a longer cell life since it doesn't need to be on as long.
    Mark
    Christian's Avatar
    Jul 2012
    304
    Let me know if you make it past 7 Mark, you will be the new champion! Good luck!
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    We're on our third season with our cell. I have found that I've had to increase the output percentage but I'm wondering if that is because it's been very hot and humid here. I did just clean my cell and there was some junk in there.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Christian's Avatar
    Jul 2012
    304
    Mickey it's most likely the temperature that is making you have to turn up your output. When it's really hot out it can make a big difference in how much chlorine your pool requires to stay at the same level.
    Dec 2009
    Chandler, AZ
    84
    Made it past 8 with my Clevaquip QuikChlor system. One of the electrodes on the cell corroded and began to leak, ruining the electrical connection. No replacement available in the US, had to install a new system.
    13000 Gallon Shasta Pool In Ground 2004
    Gunite/PebbleTech, AutoPilot Salt Water, Cartridge Filters, Ozone, In Floor Cleaner.
    Jun 2012
    Phoenix, AZ
    29
    This is my 10th year with my SWG. I just replaced my cell for the 2nd time. That is to say I'm on my third cell. First two lasted ~4 years. 40K cell on a 12K pool running 6-8 hours a day for 365 days at 60-70% output. I'll freely admit I had no idea what I was doing with my pool for the last 10 years. Someone somewhere along the line told me about CYA so I added that every once and a while, I use powdered shock every once and a while and didn't pay too close attention to my PH (or anything else). I would occasionally check the cell and clean off the scaling with MA.
    So in short, they last about 4 years if you almost completely neglect them.
    CLB
    12,000 gal Plaster, Aqua Rite SWG, Hayward Super II, Sta-Rite HRP Sand filter, Hayward Ultra Vac, TF-100.
    crustfan's Avatar
    Jul 2012
    Palm Coast, FL
    35
    I guess I got lucky with 8 years on a T-Cell 15. When I had it replaced last month it was still working but the plastic was cracked and leaking.
    Jerry
    30' x 15' ~ 15,000 gallon pool & spa, Diamond Brite, Hayward Aqua Logic PS-4, Turbo Cell T-Cell 15 SWG, EcoStar SP3400VSP pump , Star Clear Plus C17502 filter, Rheem P-M206A-EP-C heater, Caretaker 99 5-port 1.5 inch valve
    iggy's Avatar
    Jan 2008
    175
    Quote Originally Posted by calm_like_a_bomb
    CLB
    WOW! So you run your pool pump 8 hrs a day year round. Hate to see your electric bill.
    During the winter I run 45% 4hrs every other day and it maintains the clear water as well at 1.5 to 2.5 Chlorine levels.
    Late Spring and summer months I run it at 65% 4 hours a day every day and maintains 1.5 to 2 chlorine level
    I also clean my filters at least 3 to 4 times a year as here in Arizona we have lots of dust.
    Christian's Avatar
    Jul 2012
    304
    Crustfan 8 years on a T-Cell is phenomenal. That's the longest I've ever heard and I deal with a LOT of T-Cells.
    crustfan's Avatar
    Jul 2012
    Palm Coast, FL
    35
    FYI, it may not be true. I'm new to maintaining my Mom's pool and equipment and double-checked with her. She's foggy on when she last replaced the cell. I thought it was the original from 2004.
    Jerry
    Christian's Avatar
    Jul 2012
    304
    I'll put you on the record board with an asterisk.
    crustfan's Avatar
    Jul 2012
    Palm Coast, FL
    35
    Thanks. Just like Roger Maris.
    I read in Pool School - "In almost all models, the cell can be replaced when it wears out, without replacing the entire unit."
    Where can I find this part?
    Jerry
    Jun 2012
    Phoenix, AZ
    29
    Quote Originally Posted by iggy
    Yep, I run it at night though and we are on a time fo day plan 9pm-9am the rates are much cheaper than 9am-9pm. The summer the bill is ~$425 the winter its ~$120, but we pay $220 a month on the "equalizer" program.
    I'm still trying to dial in the new SWG cell, i've got it set to 50% now, and had to turn if off for a few days. I'll turn it down a few notches and see where I'm at.
    CLB
    crustfan, you should start your own topic to ask questions.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    My pool is open year-round. I run the pumps 8 hrs April - November and down to a low of 4 hrs in mid winter. T-15 cell lasted 6+ years. The system kept reading lower and lower salt levels. I just kept boosting the salt to keep it working until my real salt level was approaching double what the reading were showing and I needed to set it at 80-90% to maintain chlorine levels. But, it was still generating when I gave up and replaced it.
    chiefwej
