Results 1 to 8 of 8
Thread: Polaric 380 Back-Up Valve - Repairable?
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Polaris was working fine until the back-up valve case cracked. Strange place to crack - the nut holding the smaller half to the larger half cracked around the whole nut and the threaded part of the larger half cracked directly under that. The crack was through the whole case and almost all the way around the circumference.
    Anyway, I had another case from a previous repair. Found it, put the old valve into it and put the Polaris back into operation. Unexpectedly, especially since it had been working just minutes ago, the back-up valve failed. Ordered a new one; awaiting delivery.
    Here's the question: Can you repair a back-up valve? It looks fine. The gears all seem to mesh & turn. Hate having to spend around $50 (w/o case) for a new one if there's another solution.
    Thanks!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    South Central NJ
    3,192
    Re: Polaric 380 Back-Up Valve - Repairable?
    The gears wear.
    Scott
    Owner of - PoolGuyNJ LLC
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by PoolGuyNJ
    The gears wear.
    Scott
    So, just because they look good when you've got it out of the water, when you put it back into the case and back into operation, they're not actually meshing & working properly. I get it.
    Guess that's one argument for not running the Polaris 24/7.
    Thanks!
    TF-100 test kit.
    Jul 2012
    Basking Ridge, NJ
    46
    Does the booster pump have a recommended run time? I've never heard anyone talk about running the Polaris 24/7 so I'm interested to see what the pump manufacturer says about it.
    More to the point, I do not know that they sell the internal gears separately or as part of a rebuild kit. If the casing is cracked, they do sell that separately as part G54.
    28,000 Gal Pool w/ Attached raised Spa, White Plaster Finish, D.E. Filter - FNSP 60 sq. ft., Whisperflo Pump, Nature 2 Element (Housing Only Now Devoid of Cart.), Hayward CL200 In-Line Automatic Pool Chemical Feeder, RayPak Gas-fired Heater, Polaris 380, Zodiac 1.5-HP 240-Volt Polaris QT Spa Blower
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by PMellin
    Does the booster pump have a recommended run time? No idea.
    I've never heard anyone talk about running the Polaris 24/7 so I'm interested to see what the pump manufacturer says about it. I've just thrown it in the pool and let it run for days at a time w/o any thought of turning it off. When it's working, it's kind of like out of sight, out of mind.
    More to the point, I do not know that they sell the internal gears separately or as part of a rebuild kit. If the casing is cracked, they do sell that separately as part G54. I think you're right about the gears for the back-up valve. And, except for the first time I replaced one, I've always just bought the back-up valve mechanism. Didn't know originally that you could buy just the valve and never in 17 years, up til now, did I ever have any problem with the case.
    TF-100 test kit.
    Jan 2011
    Richmond, Texas
    595
    I just had to purchase a new back up valve as mine was cracked. I got a original Polaris part which is case and gears for 48.21 including tax and free shipping on Amazon. Just a heads up if you are going to spend 50 on just the gear mechanism you can buy the entire thing for less.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by Flippy
    You couldn't last Sunday. I only searched on 2 places, Amazon & eBay, and bought the cheapest new one I found. I don't doubt your comment, though. My experience has been that prices change as often as daily, as new/different sellers show up.
    Cheers!
    TF-100 test kit.
    Jan 2011
    Richmond, Texas
    595
    Quote Originally Posted by CUTiger78
    Cheers!
    I have seen the prices on Amazon fluctuate in a day. I seriously think they know what you are searching for and raise the price.
