Thread: Pump for 10'x30"?
    Pump for 10'x30"?
    We recently bought a Summer Escapes 10'x30" pool. It holds approximately 1,100 gallons. The probelm is I have quickly come to realize the 600gph pump that came with it is total garbage. To get ANY water to flow out of it, the filter has to be washed out every day. The only good thing about it so far is that I can put chlorine tablets into the filter. Not much to be excited about!
    I have decided to get a new pump. I am looking at the Intex 1600gph sand filter. Is this pump to big for our pool? If this pump wouldnt work for our pool, recommendations would be greatly accepted!
    Thanks!
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: Pump for 10'x30"?
    Nope. It isn't too big. They make a 1200 gph one as well. I had the 2650 gph on my 12'x36" last year so the 1600 is not too big for your pool.
    One thing you might want to consider is if you will be getting a larger pool in the next couple of years. That might dictate you getting a larger filter. If you think you might get a larger pool then don't bother with the 1200 gph.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
