Thread: Advice on purchasing an above ground replacement pool liner
    DEP1977
    Guest
    I currently have a 27' foot round pool with 52" walls and an overlap liner. I am considering buying a bead receiver to convert my pool so I can install a replacement beaded liner myself which appears would be easier to install than a overlap liner to install. A few things I am not clear on. My old liner was a 20ml. What I am seeing online are 20 gauge or 25 gauge. I am thinking about 25 gauge because of the longer warranty. Is that the wise choice? Because of the expense if the new liner and water to be hauled in I want to buy a good quality liner but am not clear on what companies, online, are reputable. Can anyone give me some advice on liner thickness, tricks for installing a beaded liner and a good reputable company to buy a beaded liner from? I am currently looking on Poolsupplies.com and pooldeals.com. Has anyone ever bought a liner off either of these companies? Thank you in advance for your advice and help.
    poolgranny's Avatar
    May 2012
    Mid-Missouri
    120
    Re: Advice on purchasing an above ground replacement pool li
    When we purchased our liner I did so through one of the online dealers. Unfortunately I can't remember the name.
    I called to place the order as I had questions and they were very helpful. Since I have grandkids they suggested going with the 25 guage. If I remember there wasn't a great deal of price difference. I was told that the 25 guage was thicker than the 20 guage and would be more durable since things would be bumping into the side of the pool (pool toys, kids, etc.). I did purchase the solid blue as it was cheaper than the patterns.
    It has been very durable and has been in use since 2007. This summer we finally got our first tear which is approximately an inch in length at the upper end of the water line. I fixed it with a patch. If I had to guess it looks like someone may have punctured it with a toenail or fingernail since the shape is similar.
    What was good was that person taking the order threw in an "install" kit of new coping strips, skimmer gaskets, eyeball gasket, and some other things since it was a "new" order.
    Above Ground Pool 15' by 30' Older pool -- Make ? Model ? Cost - Free; Given to Us
    Gallons approximately 11,000 (if I figured correctly)
    New liner in 2007 when pool was moved and installed by son-in-law and family members
    Hayward Sand Filter 150 pounds of sand (purchased new in 2007)
    White River 2 horsepower pump (purchased new in 2012)
    Deck built in 2011
    Bioguard 1200V Multi-Test Kit with an additional Orthotolidine Chlorine Test Kit
    Guest
    We ordered our inground vinyl liner this year from In The Swim, they carry both IG and AG, we ha were happy with our purchase.
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    I purchased my liner from poolsupplies.com. I shopped several different websites and this one had the best deals. I am very happy with my liner going on two years now.
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    Central NJ
    98
    I purchased a solar cover from pooldeals and they sent the wrong cover. TERRIBLE customer service - one of the responses I got was that solar cover absorb water and get heavier over time. C'mon. They would not admit the shipping mistake. I finally called the manufacturer of the cover and they told me they shipped the wrong cover and sent me the correct one. Thankfully, the manufacturer made good. As for PoolDeals, I would never buy again.
    10K IG fiberglass pool, Hayward 24" Sand Filter, 1.5HP Hayward superpump, Heat Pump Heater
