Thread: Cleaning SWG with CLR ?
    Hi there !
    Post numero uno..
    I have had a salt water pool for some years now and didn't know about this forum !
    Oh well..
    I just thought I would mention that I clean my SWG (Hayward Turbo T-Cell 15 + Aqua Rite) monthly by screwing it into it's stand and filling it with CLR. It froths and bubbles for about 15 mins then settles down. I then rinse it out and screw it back in..
    Can anyone see a problem with the combination of CLR and a SWG ? Seems to work well..
    Steve.
    South Central NJ
    3,192
    Re: Cleaning SWG with CLR ?
    A mix of 1 part acid and 3 parts water poured in the cell and left till the frothing is done I'll bet is cheaper and the recommended way for most cells.
    Scott
    Owner of - PoolGuyNJ LLC
    Jul 2010
    ontario canada
    22
    What type of acid to use is the borax workable with 3 pt water to clean the SWG cell?
    Intex 16' round 42" deep SWG pool , 15,094 L water capacity ,1000 GPH Intex Filter Pump Krystal Clear Model 637
    South Central NJ
    3,192
    Muriatic is the right stuff you want to use. Home Depot, Lowes, and most concrete supply shops have it for about $6/gallon.
    Scott
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    572
    I just finished cleaning my cell, using 4 parts water and 1 part muratic acid. This is what the manufacturer recommends so whatever the manufacturer of your cell recommends is what I would use.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
