Results 1 to 11 of 11
Thread: DIY aerator - support question
    Apr 2009
    South Texas
    177
    My boys made me a pvc aerator. Good news - in 18 hours it dropped the water temp from 95 to 84 and lowered the TA from 210 to 160. And that's with the pump on low. Bad news - the weight seems to be pulling the pool wall inward and I'm afraid the liner will pull away from the jet/washer going thru the wall. I've searched for other diy pics but can't find any that show how they are supported for AGPs. The pics focus more on the shape, holes, and hole sizes. Ideas?
    Just bought a new house in the country, no pool yet. :(
    Hot tub..500 gals..bromine
    TF100 test kit and speedstir
    38,274
    Re: DIY aerator - support question
    An aerator does not lower TA ... so that is odd. Unless you were adding acid and allowing the aeration to raise the pH and then repeating.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Can you post a picture of the aerator in use? That will give us a better idea what solution may work for you.
    Love TFP? Become a
    TFP Supporter!
    Apr 2009
    South Texas
    177
    Yes, my bad. I did not provide every detail. I can't just add MA willy nilly and bottom out my PH. So I aerate to get PH back up. Point is I was trying to lower TA (via MA, aerate, repeat) and it's working. I cannot accomplish that without the aerator. But I can't have the aerator cause a leak so I was hoping someone has some ideas on how to support it. The weight is obviously not an issue for IGPs with solid walls and that's a good many of the DIY pics. With the wealth of knowledge on this site I'm betting someone with an AGP has support ideas. Thanks.
    Apr 2009
    South Texas
    177
    Zea3 - it's too dark here now to take a pic. I will tomorrow. In the meantime, it's a 2' piece of pvc screwed into the jet with a simple T at the end that's about 12" long with holes drilled into it. Part of the 2' piece has an angle to get the head above water. Thanks!
    38,274
    Ok. Just wanted to make sure no new people might think the aerator was actually lowering the TA. Nice that it is working that fast.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Is your return hard plumbed? Mine is and the aerator I made is only about 8-10" (I have it slightly tilted to rest on the coping, it sits about 1/2" above when straight up) but even without being tilted it doesn't seem to be putting any pressure on the wall. I'm assuming this is because of the external hard pipe providing most of the support.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Apr 2009
    South Texas
    177
    No, it has flexible black tubing from the pump to the return. And my fear happened. It's leaking around the jet and water is going between the liner and the wall. How do we fix it? Drain the pool to below the jet and take it out? Maybe it's just pulled the seal out of place? Because the liner looks to still be behind it. UGH. Any help would be much appreciated. Lesson learned. The pull was so slight that I didn't notice till I happened to be at the right angle to the wall to see the flex in the wall.
    I've been lucky so far and haven't had any liner problems. I've seen people suggest patches before depending on the circumstance, so there might be an easy fix. Someone will likely chime in with good advice soon.
    Aaron
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    I have mine supported with a metal brace attached to the resin top. I know alot of people dont like to attach things to it but it works.
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    asxetos's Avatar
    Jul 2012
    Athens, Greece
    99
    Quote Originally Posted by erivette
    ... the weight seems to be pulling the pool wall inward and I'm afraid the liner will pull away from the jet/washer going thru the wall.
    You could use something like that to support the weight.
    intex-easy-set-skimmer-bracket-t36157.html
    Donīt be fooled by the sheep on my bike, I swim with fish in my sound equipped pool.
