Results 1 to 7 of 7
Thread: Should I get the 40K gallon cell for a 24K gallon pool?
    May 2012
    Austin, TX
    140
    Should I get the 40,000 gallon cell for a 24,000 gallon pool?
    I think I read to get the biggest cell you can afford. Is this the way to go?
    Thanks!
    David
    ~23,500 Gallon In-Ground Plaster Pool, Intelliflo VS+ Pump, Hayward 4820 DE Filter, IntelliChlor IC40 SWG
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Should I get the 40K gallon cell for a 24K gallon pool?
    Our general recommendation is to go 1.5-3 times your pool size, so even a 60K wouldn't hurt.
    Aug 2010
    Dallas, TX
    4,052
    I would. But I'd wait for more input.
    I'm running a 60,000 gallon CompuPool on a 44,000 gallon pool, and it seems to be just right, very happy with it. The 60k is only $110 more.
    22,551
    That would be a good size. You don't want to go much bigger than 3x the pool size because the granularity of the settings get too great.
    May 2012
    Austin, TX
    140
    Thanks all for the input
    May 2012
    Florence, AL
    20
    I'm running a Jandy 1400 40k gal cell on our 33k gal pool. Pump runs 24/7 and 35-40% duty cycle on the cell keeps me between 5 and 6ppm FC. 40% has kept up with 93 degree water temps and ambient air temps in the high 90s or low 100s with 10 hrs of direct sunlight per day and 70ppm CYA. I expect to be able to dial it back significantly once the air and water temps drop this fall.
    Based on only my experience so far with this unit. I think you could get away with a SWG sized a moderate amount above your pool capacity IF you run the pump most of the time. In my case I think my unit might be able to keep up with a 12hr pump duty cycle, but any less than that and the cell wouldn't be enough.
    I know I'm just a newb here, but I wanted to give back since lurking in this forum along with the TF100 has given me the tools to whip the pool into shape and keep it there.
    33k Gallon IG Freeform Gunite built in 1989 - Renovated Spring 2012 with Diamondbrite Plaster and elevated spa converted to waterfall
    Jandy Aqualink PDA Automation & Control System - Jandy PlusHP 1.5hp Full rated Pump - Hayward 36in Sand Filter - Jandy Aquapure 1400 SWCG
    TF100 Test Kit
    Jun 2012
    NJ
    50
    I have a CircuPool RJ45 (45k gallon) on a 24,000 gallon pool. Running for 8 hours per day on 30% has kept me at 5.5 FC.
    24,000 gallon in-ground plaster, Pentair FNSP60 60 sq. ft. DE filter @ 9,000 GPH, 2HP WhisperFlo pump, CircuPool RJ45 SWG, 399k BTU Raypak heater, built 2008. Taylor K2006C kit.
