Thread: Setup for least amount of fuss.
    nazran's Avatar
    Jul 2012
    Dallas Ft Worth
    55
    Sorry newbie question - Is the salt water generator and sand filter the best option for the least amount of post install work?
    Pool: 33,000 Gallon IG Pool w/ Hot Tub, Plaster
    Filter: Triton Clean and Clear Plus (Pleatco PCC105 26" x 7" Filters)
    SWG: Heyward Aquarite Panel + New Cell Summer 2015
    Pumps: Intelliflo VFP + Polaris PB40-60
    Cleaner: Letro legend
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Setup for least amount of fuss.
    Might need more details.
    Read about filter options here
    Read about SWG here
    In my opinion the sand filters are pretty easy no fuss compared to DE but I have never used anything but Sand.
    I don't have an SWG and cannot compare.
    May 2012
    Boyd, Texas
    93
    I think the SWG requires less work than manually adding chlorine every day. I still check the chlorine level daily, and on occasion have to add a small amount using bleach but overall I'm happy with the SWG.
    Oh and the sand filter is awesome. Clean the skimmer when it gets debris in it and every once in awhile backwash. I'm on day 10 with no backwash and pressure hasn't risen very much so...very little work in my opinion.
    6500 gal, Intex 18'x48" above ground, 1hp Pro Sand Filter, TF100 Test Kit
