Results 1 to 8 of 8
Thread: Cracked Filter head repair on EC 75A
    The Filter head {Dome Lid} on my Hayward Perflex EC 75 has a tiny hairline crack about an inch long that emits a continuous drip. I would think it could be fixed but would like to know what sealant is recomended for this repair.
    South Central NJ
    3,192
    Re: Cracked Filter head repair on EC 75A
    I suspect, as you do, you will need a new lid. Where on the lid is it cracked?
    Scott
    Owner of - PoolGuyNJ LLC
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I agree trying to patch any type of cracked pressure vessel is almost always a bad idea.
    Jul 2011
    Myrtle Beach, SC aka Redneck Riveria
    125
    Definitively not a good idea. Filters expand with pressure and contract when the pump is off. I'm unaware of any adhesive that is water tight and does that and still is able to substain 10-30 psi.
    "When your pool is sick, call the doctor, I make house calls"
    One stop pool shop, I do everything but install them. 9+ years of experience.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Do you a photo of the crack? Just making sure I understand where exactly your crack is.
    -- Guy --
    The crack is located about two inches above the lip that the cover seats on. It is too small to capture in a photo, I have to keep wiping it with a cloth to see where it is. It is solid all the way around it. It seems strange that it would crack like that (filter is three years old) Hayward has suggested a marine epoxy. If some of the pipe dopes work on the inside of a 110 PSI pipe that carrys both hot and cold water (subject to expansion and contraction in combination with the pressure) it seems in theory that it would work. I was hoping someone had already been through the trial and error phase. Thanks folks for you responses and any further suggestions.
    Kelly
    Jun 2007
    Poughquag, NY
    217
    One thing you might try is MarineTex. The stuff is awesome for fiberglass and other repairs. I don't think it will add any strength to the area of the crack, but it probably will seal the leak.
    20 x 40 vinyl IG. SWG. Solar. Ikeric VS pump.
    Thank you for all the responses. Upon researching some suggestions I found that Marine Tex flex would be most likely to satisfy the requirements. With more thought I decided to do it the best way and replace the Hayward top. Interesting though, I found that there are other manufacturers now making generic Hayward parts at much reduced prices.
