Thread: HTH Salt test strips??
    Aug 2009
    SW Wisconsin
    518
    I bought a bottle of the HTH test strips that test the level of salt in your pool water...how accurate are these? According to the strip I need to add salt, but just want to be sure I can trust these things first.
    Thanks for any help
    Dan
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Aug 2010
    Dallas, TX
    4,052
    Re: HTH Salt test strips??
    Probably close enough. I prefer the AquaChek, but you are most likely OK. How many PPM does it read? Does your SWG have a display that tells you your PPM or does it have a low salt indicator?
    Aug 2009
    SW Wisconsin
    518
    My ppm reading is 2400ppm....my SWG does NOT have a ppm display..it just has a needle that goes into a "green section" for normal operation and a "red section" for low salt reading..that's about it.
    Dan
