Thread: Broke the plug used to drain the pump ... ideas?
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    So i have been battling a very minor suction side leak .... and got the bright idea to try and tighten the drain plug for the pump / impeller (not strainer basket) and when i went to tighten the plug it basically tore apart leaving me with a plug with a big hole in it.
    Before i try and fight with it i thought i would post here and see if anyone has any suggestions.
    At the very least i would like to confirm it is a standard right hand thread??
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Re: Broke the plug used to drain the pump ... ideas?
    It's plastic correct. Use an screw extraction tool. Essentially, it's a progressive drill bit with reverse threads, so it's slightly conical. They come in all sizes. I would drill a hole through the center of the plug and get a screw extraction tool that is suited for the drill size. You can also progressively drill bigger holes until the plug can be bent and taken out. Either way it shouldn't be too hard with a plastic plug. It should be a standard right hand thread. You could also drill two holes apart from each other and use a pair of needle-nose pliers to unscrew the plug.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Nov 2011
    Albany, NY
    495
    Quote Originally Posted by XsAllOverIt
    thanks .... off to lowes!
    Haywood Sand Filter
    Vinyl Liner
    Jul 2009
    Long Island, NY
    267
    I agree with XsAllOverIt. I have done this twice and have had no problem getting the broken plug out. Good luck.
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    Nov 2011
    Albany, NY
    495
    well i bought an extractor ... guessed on the size and it turns out the one i got was too big
    the good news is i realized it before i did any damage so it's back to the hardware store for the right size
    i bought the correct plug the first time so i am hoping it is straightforward from here on out
    Haywood Sand Filter
    Vinyl Liner
