Thread: First week with new pool
    Jul 2012
    Caddo Mills, Tx
    33
    Filled the pool up last Friday night. Kids swam an hour or two sat evening and 7 hrs on Sunday. Everyone left Mon so I started adding chemicals. Added 96 oz Bleach, two containers of CYA (think it
    Was HTH stabilzuer&conditioner 4lbs ea) in two socks , added 160lbs of salt. Let pump run 24 hrs.. TF100 arrived Tues. and added another 240 lbs of salt and another 192oz of bleach. Let pump run another 24hrs. Yesterday morning I turned on SWG for 8hrs and pump for 12 more hrs. My SWG is now running for 8hrs and pump for another 12. Water is blue. I have noticed dirt or sand settling in spots on bottom of pool, tends to gather at seams. This more I brushed and it disappeared into water. I'm thinking I need to vacuum. Below are my yes results for each day.
    Mon before any chemicals using HTH 6wat kit
    TA 80
    pH 7.8
    CH 70
    Copper .2-.5
    ClBr .5-1
    Tues
    TA 90
    FC 1
    Cc 1
    TC 2
    TA 90
    pH 7.2
    ClBr .5-1
    Salt 1690
    Wed.
    ClBr 1-2
    pH 7.2
    Salt 3520
    FC 3
    CC .5
    TC 3.5
    TA 90
    CH 130
    Copper .5
    This A.M.
    ClBr 1-2
    FC 2.5
    CC .5
    TC 3.0
    TA 90
    pH 7.2
    Salt 3520
    CYA still dissolving out of socks. Almost gone in one of them. Please tell me what you see and what I need to correct. Keep in mind this is my first rodeo with pool chemicals and testing. I
    Following g the instructions but colors don't always look right to me. I have BORAX, BAKING SODA, and Muiratic Acid waiting to be used but I thought it best to get chlorine and CYA going right first.
    Shawn
    14,362 gallons - Intex Rectanglar Ultra Fame 32'X16'X52" ABG
    Model SF20110 Intex Sand Filter Pump (Max Working Pressure 50 PSI, Max Flow rate: 2650gal/hr)
    With An Intex Krystal Clear SWG Model CS8110
    Caddo Mills, Tx (20 miles East of Dallas...temps low 20s to 110)
    [b]July 19, 2012 Intsall[/
    Aug 2010
    Dallas, TX
    4,052
    Re: First week with new pool
    Your FC is too low. Also, I don't see any CYA measurements, don't go adding too much before you can measure CYA accurately.
    Jul 2012
    Caddo Mills, Tx
    33
    Cya didn't measure yesterday. All the posts I read said it takes a week. Should I try to test it now, on the fourth day?
    Shawn
    Aug 2010
    Dallas, TX
    4,052
    Keep waiting, I forgot you said it was a new pool. Oops! Obviously you were starting at 0.
    Get your FC up with bleach until the SWG can keep up on its own.
    Jul 2012
    Caddo Mills, Tx
    33
    Thought the bleach recommendation was coming. Thanks!
    Shawn
    Apr 2012
    SW Ohio
    456
    The 4 lbs of stabilizer you put in should raise your cya level to? Using the pool calculator add enough bleach to raise your fc to the target per you cya and then let the swg try to keep it there but you will have to adjust the run time on your swg until you find your pools sweet spot. So if the cya you put into the pool is suppose to be 30 ppm then assume it is that and use the chlorine/cya chart to get you min and target fc and dose it to the target range
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
