Thread: Aquabot Classic - Drive Motor Issues
    Over the past several days I've had an odd issue with our Aquabot. When I first put it in the pool it runs around the pool as it should. After about 5 minutes the drive motor shuts off and the Aquabot sits there just pumping water. I turn it off, let it sit and it runs again. I have had the belts checked and the wiring looked at by a service center.
    Any other thoughts besides a new $500 drive motor?
    Also since $500 for a drive motor is about 1/2 the price of a new one, if that is really the problem does anyone recommend any of the other cleaners (be the other Aquabot's or other brands?)
    Thanks for your help
    South Central NJ
    3,192
    Re: Aquabot Classic - Drive Motor Issues
    Test with a supply too.
    Scott
    Owner of - PoolGuyNJ LLC
    I have tested it with multiple power supplies and the issue exists with both. I'm hoping that perhaps there is just a loose wire, it actually made it through a full 7 hour clean cycle today, we'll see.
