Results 1 to 16 of 16
Thread: What should come first...sand filter? Or SWG for 16x48 agp
    Jun 2012
    Southern California
    10
    I can only afford one or the other this summer. And now that they are starting to go on sale i need some advice. Does anyone recommend getting a sand filter first and then next year maybe a SWG (intex Krystal clear)? Or the other way around. I use the BBB method and my pool water is amazing. Should I just continue with the Clorox and get a sand filter?
    Thank you
    I love, love, love my Summer Escapes pro series pool!!!!
    Summer Escapes 16x48 Pro series Metal frame AG (6,041 gallon)
    In wall skimmer / filter C cartridge
    BBB method
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: What should come first...sand filter? Or SWG for 16x48 a
    Definitely the sand filter. Those stock cartridges are useless.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    I second the choice of sand filter. You won't be disappointed. Switching to SWG hasn't been half as exciting as I expected it to be, but the sand filter I am in love with!
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    22,553
    X3 on the sand filter first!
    Apr 2012
    SW Ohio
    456
    X4 sand filter all the way
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    x5 sand filter all the way
    13500 gallons
    Intex 2650 Sand filter pump
    AG
    May 2012
    Boyd, Texas
    93
    Definitely the SWG.....Just kidding, sand filter all the way. :P
    6500 gal, Intex 18'x48" above ground, 1hp Pro Sand Filter, TF100 Test Kit
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Just in case there is any question..sand filter is a NEED for your pool, SWG a want. Needs before wants in my book.
    -- Guy --
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Sand filter. You can use bleach to do the same job as an SWG. But your stock pump and filter cannot do near the quality job as a sand filter. In other words, an SWG cannot do anything that you can't do with bleach. It's not a necessity. To get good filtering, you need to replace the stock pump/filter system.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Jun 2012
    Southern California
    10
    Thanks everyone...sand filter it is. What size? 1600?
    That's what I love about asking questions here....I had a pool store person laugh at me when I answered his question about what kind of chlorine I used. He told me "pool" chlorine was NOT the same as Clorox, and then tried to sell me shock, pucks , clarifier, phoso stuff. UGH!!! I left the store with a .69 cent clearance item, and a vow to never go back.
    BBB method
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Kargar4
    What size? 1600?
    My neighbor has a 1600 with the same size pool as yours and it has worked great for him, including cleaning up two algae outbreaks . With that said, there are reports here on tfp that suggest that intex 2650 sand filter is a good step up in terms of being able to vacuum better, not that the 1600 can't vacuum. Also, one user of the 2650 that plumbed it to their existing return collar fitting had problems with the return adapter "blowing off".
    May 2012
    Boyd, Texas
    93
    I bought the 1600 for my 18' pool and it seems to be doing a great job. Run it about 8 hours a day and it keeps it all pretty clean.
    May 2012
    Boyd, Texas
    93
    Just FYI walmart appears to be having a sale on it right now. I believe I paid like $175. http://www.walmart.com/ip/Intex-Krys...tlyViewedItems
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    That is a good price...almost as good as last years walmart buy a 1600 and get a free swg ...or something like that.
    Jul 2011
    844
    2 friends have the same pool as me (8,000) gallons. I have the 2650 sand filter, they both have the 1600. Their pools are just as clear as mine (fantastic in other words!!), and they are having no problems at all with pool maintenance, circulation, or filtering whatsoever. The only difference is backwashing. They will probably have to backwash a bit more than I do. Not a big deal. That being said, when it comes to filtering, bigger is always better, but better is not always necessary.
    Bestway SWG
    How could you not have known they were different, the labels aren't even the same!
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
