Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: Newby here.
    SunnyinSC's Avatar
    Jul 2012
    North Augusta, SC
    23
    Newby here.
    Hi wonderful people,
    We installed a vinyl pool last September and opened it early June. We had it covered for the winter which is mild here. The water looked great had it tested several times in June and got the analysis from the pool people as to what it needed. Never walked out the door less than 150 bucks. We thought we were fine, then this green stuff started showing up. Took more water up there and told then there was green stuff in our pool. Never once did algae come up. We bought the recommened expensive chemicals and still had the green stuff. So off to Google I went. And thanks to a friend of mine that led me to this wonderful site, but my husband is a stuburn man and I had to fight him to listen to me and my friend!
    We bought the TF-100 and I am checking the FC CC PH T/A CH and CYA every morning since 7/15. We are using the calculator and plugging in our numbers. My husband is buying the chlorine, the muriatic acid, baking soda, borax
    We were running our pump per the pool people 8 hrs in the day. My friend told us to maybe run it at night and incease the hrs. So we did. Now it is running 10 hrs from 5PM to 5 AM.
    Here are some #'s and I know yall like #'s
    7/15
    fc 2.5
    cc.5
    ph 7.5
    TA 90
    CH 260
    CYA 40
    still green stuff so we shocked it! we thought
    7/16
    fc 10.5
    cc 0
    ph 7.3
    TA 100
    Ch 250
    cya 90
    did the OCLT that day and next day
    fc 8.5 PM
    cc .5
    fc 8
    cc 0 AM
    still sweeping algae when we brush
    7/17
    fc 8
    cc.5
    ph 7.5
    TA 80
    ch 250
    cya 70
    The numbers are pretty much the same until we until we kept sweeping green algae and shocked the **** out of it on 7/23
    fc 20.5
    ph 8.2
    TA still 110
    ch 250
    cya 90
    today...
    fc 16
    ph 7.4 we put acid in per the online computerr calculater
    TA 110
    CH 220
    CYA 90
    Temp has always been 82-84.
    Are we on the right path? Haven't had it one season and we of course never having a pool are so confused
    I am sure I have left out pert info so please let me know.
    Thanks for sharing knowledge we never had before buying a huge investment we never knew how to take care of.
    32' by 16' vinyl inground pool 21,760 gal
    Haywood motor 300#62 GPM Sand Filter
    compupool SWCG
    200w magnetic power pack model #EE0124BK
    3 feet to 8 feet depth.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Newby here.
    Welcome to tfp, SunnyinSC
    Quote Originally Posted by SunnyinSC
    You mention sweeping green algae...is the water clear or cloudy and is the stuff just on the floor?
    Most of your test numbers look good, though your cya values are high and your earlier tests seem somewhat erratic (went up from 40 to 90 in one day between the 15th and 16th?). [s:2kqi5zo2]The first thing I would do is a partial drain and refill to get your cya down at 50 ppm. Then deal with the rest.[/s:2kqi5zo2] The range for the saltwater chlorine generator (swg) is 70-80, so you are a little high, draining just a bit might be worth it now.
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Re: Newby here.
    CYA numbers are questionable to me.
    If you're running the pump at night, what percentage on your SWG? Your pool is in full sun-perhaps someone here will advise if its better to run the pump during the day or night? I recall your PB (since he's mine too) saying that the hottest part of the summer could require the pump to be run for up to 12 hours. So that's something that can get tweaked (along with the % on the SWG)
    Yippee
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Newby here.
    I missed the fact that your pool has a swg (thanks YS) in my above post...corrected now. If you were doing the Overnight chlorine loss test (OCLT) with the swg on, turn it off for the next OCLT you do.
    SunnyinSC's Avatar
    Jul 2012
    North Augusta, SC
    23
    Re: Newby here.
    the SWG was off at the time I did the OCLT. Ours is set to run from 6pm to 6am. The sun is gone by then and I get home from wprk at 7am so I am out there testing at around 830ish?
    compupool SWCG
    SunnyinSC's Avatar
    Jul 2012
    North Augusta, SC
    23
    Re: Newby here.
    should I get an FC level now?
    compupool SWCG
    SunnyinSC's Avatar
    Jul 2012
    North Augusta, SC
    23
    Re: Newby here.
    husband added more chlorine tonight since the level went from 20.5 yesterday to 16 this morning and 0 CC. And I still swept green algae. We are at witts end here!!!
    compupool SWCG
    SunnyinSC's Avatar
    Jul 2012
    North Augusta, SC
    23
    Re: Newby here.
    Quote Originally Posted by YippeeSkippy
    Yippee
    compupool SWCG
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: Newby here.
    Yes, FC and TC please, and thank you.
    If it's under 10ppm, run pH as well. I'm afraid when you added acid to adjust pH earlier that the result was skewed due to the FC being over 10ppm. (for future reference, don't check pH when FC is over 10ppm, the results aren't valid).
    Can you tell us what the water looks like? Do you still see green stuff on the floor?
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: Newby here.
    I just checked the calculator, and for your CYA level of 90, shock level is actually 23ppm. I'm afraid you're not actually at shock level. There's little explanation otherwise why the green is remaining.
    Bump the FC up to at least 23ppm, and for overnnight I'd say run it all the way up to 30ppm actually. Your pool is safe up to 49ppm (MA shock level).
    Tomorrow, make sure it is above 23ppm all day. Are you able to test and dose throughout the day or will you be away for a number of hours? If you've got to be gone, do the same as tonight so that the water won't drop below 23ppm. After you see how much is lost overnight you'll have a better idea how much you will lose to algae tomorrow. Add 4-5ppm to that to allow for sun.
    SunnyinSC's Avatar
    Jul 2012
    North Augusta, SC
    23
    Re: Newby here.
    frogabog, the water looks great! it is just when I swept it I saw stuff. I assume it is algae. Hate to assume! going to ck the FC now. This might be as trying as when I had to do a diabetes curve on my cat! water not cat's ear.. good!
    compupool SWCG
    SunnyinSC's Avatar
    Jul 2012
    North Augusta, SC
    23
    Re: Newby here.
    The FC is at 17.5 now. no CC.. not sure I have enough clorine to put in there tonight. Will take my husbands chlorine for his laundry which is half full of a 182 fl oz jug and add it?? Yes my husband does the washing around here.
    compupool SWCG
    SunnyinSC's Avatar
    Jul 2012
    North Augusta, SC
    23
    Re: Newby here.
    I can test this in my sleep. Will (ugggg) wake up in the am and test when hubby goes to work at 0645.
    compupool SWCG
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: Newby here.
    I think you'll see some improvement if you can keep it at or above 23ppm full time. It'll be a little ordeal for a while, but the results will be worth it and in the end you'll feel quite empowered :~}
    It seriously is time to fire the pool guy though. You can do this, you're doing the hard work already anyway. In the end, you won't have to work half as hard as he does either.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: Newby here.
    You can get him some new bleach. Use it tonight and bring it up to 30 if you can.
    SunnyinSC's Avatar
    Jul 2012
    North Augusta, SC
    23
    Re: Newby here.
    holy **** 30 really? so if we keep it at this level when we sweep can we expect NO green dust at the shallow end? I will be dropping drops for days at 30. But what ever will get that green monster to leave us alone we will do it.
    compupool SWCG
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: Newby here.
    By following the shocking process you can expect to have and enjoy a nice clean algae free pool, yes. Of course!
    It's worth it. After you're done you'll maintain appropriate FC levels and should not see algae again :~}
    30ppm should allow you to not fall below shock level overnight. If you can test and re-dose hourly tomorrow I'd say just dose enough extra over 23ppm to get you through to the next test. You don't need to hold it at 30 tomorrow if you can be there to maintain at least 23ppm all day.
    May 2011
    Clearwater, FL.
    446
    Re: Newby here.
    Hi SunnyinSC and welcome to TFP!
    I would for sure keep that chlorine level up close to 30ppm, no your not going to hurt anything but the algae.
    With CYA levels high up in the range for a SWG pool, your cya is binding a large percent of your chlorine. This is the reason you need to be so high on your chlorine ppm.
    Stay the course and the pool will behave and do as it's told.
    Read, read and read here and it will all make sense very soon.
    If you find a mod you like here, go and read their postings as they are very smart!
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    SunnyinSC's Avatar
    Jul 2012
    North Augusta, SC
    23
    Re: Newby here.
    Thanks for all the advice. I checked the FC this am and it was the same as last night at 17.5. My husband is adding chlorine tonight and will keep adding until we reach a level of 30. I work night shift so I will ck it tonight and in the morning.
    compupool SWCG
  20. Back To Top    #20
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Newby here.
    With a OCLT of 0 ppm, CC of 0, and clear water (other than the "dust") it seems that you do not have algae.
    Is any of the "dust" up on the vertical walls?
    Could the "dust" be pollen?
    Any chance you could post pics?
