Results 1 to 7 of 7
Thread: high clorine level
    high clorine level
    after having the pool covered for a couple of days the Chlorine Drop test was off the chart (dark yellow). We have had the SWG off for several days but the Chlorine is still off the chart. The water looks great but should we be concerned? Should we do something to lower the level?
    Central PA, 22500 gall IG, vinyl, Pentair Intelli-Flow variable speed pump, sand filter, Pentair Intelli-Clor SWG
    Aug 2010
    Dallas, TX
    4,052
    Re: high clorine level
    It should be coming down on its own. You might consider getting a FAS-DPD chlorine test so you can accurately test your TC at high levels.
    http://tftestkits.net/FAS-DPD-Chlorine- ... t-p47.html
    38,537
    Also realize that the OTO test measures TC (total chlorine = FC + CC). So, it could look high because of high CC (not good).
    Since your water sounds clear, that is less likely, but another reason to invest in a good test kit.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    Take the cover off and let some sunlight get to the chlorine.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Jun 2010
    Glendale, CA
    513
    As mentioned - taking the cover off will speed up the break down of chlorine fairly rapidly.
    One thing to keep in mind - your idea of "very high chlorine" isn't taking CYA into account. A very yellow OTO test (10-15ppm) is most likely somewhere below the correct shock level for your pool - but it all depends on the CYA level. If you know your CYA level post it and we can help you get a sense of how "high" your chlorine levels actually were/are.
    There is a lot of great information in Pool School about the CYA/FC relationship and how it works.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    Feb 2008
    Denton, TX
    5,061
    What is your CYA level? Without knowing that, you aren't able to know what your chlorine level needs to be.
    Sorry guys, as soon as I sent the post I knew I should have included more info.
    We do test using a T-100 kit. A couple days ago the numbers were:
    FC - 13
    CC - 0
    CYA - 65
    Thanks again for any input. This is our first season with the pool so we are definitely newbies at this.
