Thread: How often do you clean behind pool light?
    Johnl's Avatar
    May 2008
    Montgomery County, PA
    88
    It has been pretty hot here in PA and the water temp has been close to 90. I noticed some algae starting to form around the top of my pool light, so I pulled it out to clean around the light. This is the first time in 7 years I removed the light, so it was due for a cleaning.
    Has anyone else had this problem? How often do you remove your underwater light out to clean the light and housing?
    FC - 3.5
    CC - 0.0
    PH - 7.5
    TA - 110
    CH - 350
    CA - 70
    Salt - 3,000
    23K Gunite IG Pool
    Waterway Crystal Water SVL56 Pump/1.5HP AO Smith Motor
    Hayward Star-Clear Plus Cartridge Filter C17502
    Aquarite 40k SWG
    Polaris 360
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Re: How often do you clean behind pool light?
    I've only had a pool for the last couple of years. Both pools were 5-7 years old. I've only pulled lights in order replace a bulb or clean during shock process due to algae.
    So, with my limited knowledge, I would think folks never do just to clean for the heck of it.
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    When dealing w/mustard algae the advised course of action is to remove the light and clean behind it. This is not normally required w/run of the mill algae but it does not hurt to do it.
    YouTube has videos of replacement process for bulbs which includes the removal of the light.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Through 7 seasons, including changing the light, never.
    Johnl's Avatar
    May 2008
    88
    Thanks for the replies.
    23K Gunite IG Pool
    Aquarite 40k SWG
    Polaris 360
